Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Sportomatic brake question
    Dec 2003
    West Los Angeles
    I've owned a few 2.4 Sportomatics (there goes my credibility with Frank) and all have had S calipers. Ive seen a lot, as well. I believed all 2.4 Sportos came with S calipers. But I saw the ex- Bruce Anderson '72 Sporto yesterday and it had iron calipers.
    Was it just a coincidence that every other one I've seen had S calipers?
    techweenie.com
    Port Macquarie, Australia
    I thought S brakes were part of the "package"...
    John Forcier
    EarlyS #1987
    Restoration Saga
    Oct 2008
    Burford, ON, Canada
    Yes, I believe all Sporto's came with S brakes. Very unusual to have cast iron calipers; were they M or A? The A caliper would fit on the S strut, but M calipers would indicate the 'wrong' suspension.
    Dec 2003
    West Los Angeles
    Glad to see I'm not alone in my belief these Sportos came with alloy calipers.
    Dave, I just glanced at the brakes. The car is at TRE at the moment. It was a Sepia 72 Sportomatic and my former '72 Sepia Sportomatic is a couple hoists over. I'll check it out next time I'm there...
    techweenie.com
    Aug 2007
    Phila Pa. area
    I had a 1972T 911 Sporto, no aluminum calipers. I also had a 1974 911 Sporto, no aluminum calipers
    Mike
    Oct 2008
    Burford, ON, Canada
    I wonder if the spec changed at some point.
    Senior Member JT912's Avatar
    Jan 2008
    Eugene, OR
    My '68 Sporto does not have aluminum calipers.
    John Thompson
    1966 912. My first car. Bought it Nov. 25, 1988. Still have it.
    Oct 2008
    Burford, ON, Canada
    John, no the 1968 would not have the aluminum calipers, but does it have the vented rotors (911S calipers)?
    Jul 2008
    South Florida
    1968 S Sporto has vented rotors, '68 T Sporto has solid... neither came with aluminum calipers.
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    My ROW 69T originally a Sporto with the S appearance package.....vented fronts with S alloy calipers.
    I was under the opinion that it was part of the S appearance package?
    I'm not sure if these are original to the car, but judging from the rest of the car I would assume that the PO didn't upgrade them.
    Tony
  1. Sportomatic Question
    By leedurrant73 in forum Technical Info
    Last Post: 07-17-2012, 12:21 AM
  2. 1968 SWT brake question
    By mpotvin in forum Technical Info
    Last Post: 11-01-2011, 12:51 PM
  3. Early brake question
    By 304065 in forum Technical Info
    Last Post: 06-08-2010, 08:25 AM
  4. Sportomatic Shifter Parts Question-Pics!
    By Kilgore Trout in forum Technical Info
    Last Post: 07-04-2009, 05:26 AM
  5. Sportomatic shift linkage question
    By caproader in forum Technical Info
    Last Post: 05-18-2005, 02:39 PM
