Results 1 to 9 of 9
Thread: what surface finish had the brake protecting sheets on an 1967s
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    i have the brake Sheets for a 1967S now yellow chromalized but some say they should be painted black .
    what is the correct finish for them.
    thanks for your input.
    franz
    Bummer Franz, yours look great, but I'm afraid SWB cars are black!
    Franz: what are those mounting brackets? Are they specific to the "S"? They look different than those specified for the Normal. And as Ed correctly says they should be semigloss black.
    May 2013
    AUSTRIA (tu felix)
    yep they are swb 911s/911L specific(euro only? ) also the sheet is different for better airflow for the vented rotors)
    no big deal to make them semiglossy black....i anyway have to powder coat some other parts comming week.
    thanks for helping
    franz
    Jan 2011
    Sunny Southern France
    Franz,
    Would you have some other pictures of this black bracket holding the caliper? What is it made of??? Steel or Aluminium?
    Thanks a lot!
    Olivier
    Feb 2007
    Cheshire, UK
    Franz
    Not sure about black, these are original off my '68 TR (May/June '68 build), maybe they changed for '68 model year?
    Tim
    Early 911S Registry #1167
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by Bantam View Post
    Franz
    thats what i have read somewhere or some old Porsche fellow told me that they have not been painted on the early cars up to 67`
    hmmm i think i have to investigate further...
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by Olivier View Post
    Franz,
    Thanks a lot!
    Olivier
    i assume it is forged steel but it is the same as on all swbs i have seen the non vented cars have 4 mounting Points for the plate the vented ones only 3... have a look at the spare part catalouge 602-00 part 6
    is the different one.
    best
    Jan 2011
    Thank you!
    Olivier
  1. Sand blasting brake calipers - protecting the bores?
    By obrut in forum Technical Info
    Last Post: 01-06-2014, 02:16 AM
  2. 1967 911S brake caliper finish
    By mcgregor in forum Technical Info
    Last Post: 03-04-2012, 08:31 PM
  3. Brake caliper restoration finish
    By pacarguy in forum Technical Info
    Last Post: 08-13-2009, 12:18 AM
  4. Brake Rotor Hub Finish
    Last Post: 07-29-2008, 04:33 PM
  5. correct surface finish on 73-74 vinyl ??
    By TRE Cup in forum Technical Info
    Last Post: 02-02-2008, 10:27 AM
