Results 1 to 10 of 12
Thread: Seat rail issue/loose seat
    The passenger seat, which is a Recaro sport seat is loose. The repair shop said it is because the seat rails do not have the black inserts which allow the seat to be snug. I never knew the rail had this. The bolts are all tight.
    I think the part numbers for the rails are 911 521 194 00 and 911 521 196.00.
    Does anyone know if there is a part I can purchase to repair this?
    RGruppe member 445
    I may be wrong, but it's just steel to steel, maybe the later cars have a plastic slider.
    Jan 2011
    DFW TX
    My 71 with standard seats have little nylon sliders on the rails. Replacing them removed side to side slop. I got them from Stoddard.
    Thank you.
    RGruppe member 445
    That may be the solution or are you talking about the plastic pieces are white as suggested
    The rubber block at the back of the tilt mecanism does help to keep the seat
    tight when in the locked down position.
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    The runners also run on 4 nylon sections per rail. We make these if it helps
    Alan
    Quote Originally Posted by M_deJong View Post
    How many of these plastic sliders are used per seat?
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    Registry Member #921
    1972 Bahia Red 911 Coupe #9112100390..."Rudy" SOLD
    1967 Savannah Beige VW Beetle Sedan #117364457..."Heidi"...aka "Tinker Toy"
    Quote Originally Posted by FL-Frank View Post
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    I'd love to see a picture of these installed.
    Hi, on sport seats there are 8 per seat. Here are some we made
    HTH
    Alan
  1. FS: 914-6 GT Seat rail sliders
    By Bernie B in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 03-10-2014, 10:23 PM
  2. Seat rail screws
    By NorthernThrux in forum Technical Info
    Last Post: 12-29-2013, 06:48 PM
  3. Authenticity Issue 1969 911 Seat Rail Hardware
    By 69S-S/R in forum General Info
    Last Post: 02-11-2013, 12:57 PM
  4. WTB seat rail supports
    By 911231 in forum For Sale: 911 Parts
    Last Post: 11-18-2011, 06:01 PM
  5. Seat rail question
    By neilk in forum General Info
    Last Post: 03-17-2005, 12:11 AM
