Thread: Clamps and small brackets on oil line over trans
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    I've found that the clamps and small brackets that hold the oil line over the trans are/were missing, and are NLA.
    What size clamp should I be looking for from McMaster Carr?
    Does anyone have a photo of the small brackets that hold the clamps, so I can search for something to fit other then the tie wraps that were fitted.
    TIA
    Tony
    The clamps are simply right angled brackets, I will grab some pics unless someone else helps first. You could use a P-clip all be it this is not original.
    HTH
    Alan
    Hi Tony,
    I can help you with the correct German Norma clamps as uses originally. I make a little kit that includes the correct hardware. Attached are a couple pictures.
    Brad Davis
    brad@911rennen.com
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Nov 2004
    Gold Coast.
    PM sent Brad
    Tony
  1. Replies: 3
    Last Post: 04-15-2014, 04:32 PM
  2. WTB: SWB front bumper brackets & J-tube clamps
    By Nordschleife in forum For Sale: 911 Parts
    Last Post: 02-03-2014, 07:35 AM
  3. Replies: 5
    Last Post: 09-11-2013, 12:05 PM
  4. WTB: main oil line junction, between case and line
    By mcaterino in forum For Sale: 911 Parts
    Last Post: 12-06-2010, 04:47 PM
  5. I need these very small clamps...
    By vricardo in forum For Sale: 911 Parts
    Last Post: 11-16-2008, 06:39 AM
