Results 1 to 10 of 16
Thread: Stoddard front pan fixture
    We bought a front pan jig/fixture from Stoddards and after the first front pan done with it I'd like to report that I thought it worked very well. Saved me from having to measure umpteen times as I used to do. I realize it's not a Celette bench, but after all we are a mechanical shop not a body shop. I just do the front pans because no one I know around here will do them the way I like. I always have to cut in a new longitudinal, also notice the reinforcement piece welded in over the front A-arm attachment inserts (very important) Where ever the pan was spot welded I do the same. Once it's undercoated it shouldn't be evident a pan was done.
    Egad that spotwelder is right out of Stuttgart! Mechanical shop only indeed!
    Jul 2006
    Corvallis, OR
    Ed, I'll help you pay for that tool. I'll rent it from you! Really.
    72S, 72T now ST
    And the reason you see a new front bulkhead here is from the previous poor front pan replacement. He didn't bother to drill out spot welds, just RIPPED the metal away then covered it all up with FIBERGLASS mat and real thick undercoating,,,,,that was a real "flat rate" job,,,,,in case you wonder why some people charge more.
    Shipping that thing back and forth could be a killer Scott!
    Oct 2012
    Minneapolis
    how do you feel about this vs using a celette for the job?
    -Kris Clewell
    Professional photojournalist
    red decklid club member #1
    Hi, Porsche them selves would not use the Celette Jig to do that job alone. They made a factory tool for it, basically what has been replicated here. Here is an original unit.
    HTH
    Alan
    Well Kris I was going to answer that this fixture can't be as good as the Celette, but Alan's answer above is very interesting!
    Dec 2004
    SE Michigan
    Ed, it's always great to see the master at work! Inspiration for sure.
    I'm using Stoddard's tool right now too. On my car the adjoining metal to the pan is rotted out. So, for me, another great thing about the tool is holding the pan in place so I can form the missing metal and flange to which the pan secures.
    Bill G.
    EarlyS #718 | RGruppe #437
    Bill I tried once to form the longitudinal edges and quit. To me it is always easier to simply buy new longitudinals and butt weld them in, then everything fits as it should. I realize that adds to the cost but I decided I can't make those pieces to fit as well as the correct piece.
  1. Engine holding fixture
    By Norm01 in forum General Info
    Last Post: 08-23-2013, 07:51 PM
  2. FS: Stoddard grab bag
    Last Post: 06-18-2013, 09:38 AM
  3. Stoddard Porsche - End of an Era
    Last Post: 06-01-2011, 07:08 PM
  4. Wtb oil bypass fixture
    By mike curnow in forum For Sale: 911 Parts
    Last Post: 06-01-2011, 05:09 PM
  5. FS Workshop I and II NEW, Stoddard
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 04-23-2007, 02:01 PM
