Results 1 to 1 of 1
Thread: Mounting oem Hirschmann antenna
    I finally found a good period correct power Hirschmann antenna and have a few questions. The antenna came with two mounting brackets which are used to mount it to the inner fender. One is just a long anodized straight bracket. Based on the Porsche paperwork I have, this bracket mounts to the bottom of the antenna body. The second bracket looks nothing like the other, is much shorter in length and has a triangular top part which mounts to the inner fender,,,,, I think!?. The paperwork I have does not show a top bracket, but does show the exact bottom bracket which I have. Does anyone know if this installation gets a top bracket?
    Also, the antenna needs a power and ground connection. Can I just tap the hot lead and ground to the radio, or do I need to do something different? Also, do I need to install an inline fuse for the radio and the antenna?
    RGruppe member 445
  1. WTB: Hirschmann Antenna for '73 911
    By 1967 in forum For Sale: 911 Parts
    Last Post: 04-06-2014, 11:46 AM
  2. FS: NOS Hirschmann Auto Antenna
    By IAA1963 in forum For Sale: 911 Parts
    Last Post: 11-17-2013, 08:54 AM
  3. FS: 1970 Hirschmann Antenna and mast mounting bracket
    By NorthernThrux in forum For Sale: 911 Parts
    Last Post: 01-01-2013, 06:12 PM
  4. FS: Hirschmann Antenna
    Last Post: 10-29-2012, 01:04 PM
  5. Help with Hirschmann Antenna Hook up
    By t6dpilot in forum General Info
    Last Post: 05-12-2008, 10:04 AM
