Thread: exterior lighting wiring question
    Dec 2004
    SE Michigan
    I am redoing my front wiring harness and incorporating some driving lights and fog lights.
    Assuming that this is the way I want to wire the circuits:
    what is the best way to connect all the wires that supply power from the battery? A terminal block would be the best, but I want a factory look. I think Kenik cut down an fuse box. I want to do something along those lines, but something more finished because I do not want to put it in the smugglers box like he did.
    Maybe I could make up a harness that uses butt splices like this:
    and have a single wire connected to the battery terminal that goes into the butt splice and then four wires that come out of it. Any reason I can't/shouldn't do this? Other ideas welcome.
    I'd like to hear from people that have experience making up custom harnesses, if possible. TIA.
    Bill G.
    EarlyS #718 | RGruppe #437
    If you use those I will never speak to you again
    Dec 2004
    SE Michigan
    You cut me really deep, Ed. Really deep.
    Bill G.
    Dec 2008
    Woodland Hills, CA
    I used this...
    http://www.jwesteng.com/shop/index.p...roller=product
    There ya go Bill, now we're talking!! very neat, and electrically sound. Seriously I wish I counted all the times that I have finally traced electrical problems to butt connectors, scotch locks, wire t-taps, and best of all bare wires wrapped together then wrapped with electrical tape.
  1. MFI Microswitch Wiring Question
    By justacoupe in forum Technical Info
    Last Post: 01-13-2014, 09:22 AM
  2. Question for the Brain Trust Exterior trim
    By Minkoff in forum General Info
    Last Post: 03-08-2013, 06:48 PM
  3. H4 wiring question
    By POS in forum Technical Info
    Last Post: 09-09-2012, 09:21 PM
  4. Wiring Question(s)
    By Paul Schooley in forum Technical Info
    Last Post: 02-19-2008, 10:55 AM
  5. Door Wiring Question
    By BAPhotowerks in forum General Info
    Last Post: 04-10-2007, 09:24 PM
