Results 1 to 8 of 8
Thread: Correct aerial for 1966 coupe
    May 2011
    Chelsea, Québec
    Hi
    I want to replace the 1973 or so aerial that is on my car with one that is the same as it left the factory with. I am assuming that it will be a Hirschmann? Can anyone give me the correct details (part number, etc) and whether they are still available new or should I trawl around for one?
    Also, do I have to remove the driver's door to fit the new aerial? Any hints or tips on how to make the job easier than I think it will be are gratefully received!
    Many thanks
    Stephen
    Member #1616
    It's been my experience that you can find Hirschmans that are close, but not as long as the originals. There would have been a bracing mount down near the bottom of the antenna, the new one won't reach that same position. I use a suitable tubing size to extend the mast down to the position of the original one. Of course none of this can be (easily) done with the door on. I use the factory tool to remove the hinge pins to get the door off. You DO NOT want to unbolt the hinges.
    Sep 2006
    La Quinta
    Stephen,
    I just went through this, taking mine out to clean. I had to take the door off...
    And do what Ed said about removing the hinge pins.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
    May 2011
    Chelsea, Québec
    Thanks Ed and John... is it easy to remove the door without the factory tool?
    Member #1616
    Dec 2008
    Woodland Hills, CA
    I had to remove the door on my 72 to install the antenna.
    Quote Originally Posted by StephenAcworth View Post
    Not really, I had tried various methods years ago, then 25 years ago bought the factory slide hammer tool, no comparison. This not to say that I wasn't able to do so with more generic tools like from Snap-On and Mac, but they're difficult to use especially if the pins are really tight. However they still beat unbolting the hinges!
    Sep 2006
    La Quinta
    Stephen,
    Here's one from my '65. Sorry for the bad iPhone shot.
    Registry #983
    R Gruppe #741
    May 2011
    Chelsea, Québec
    Thanks for the photos, Eric and John. The one I was going to use does not have the tall black cover that both of yours have: seems like I'll search out the correct one before taking the door off!
    Stpehen
    Member #1616
  1. Replies: 10
    Last Post: 03-08-2013, 04:11 PM
  2. Correct Owners Manual for 1966 911
    By jaldeguer in forum General Info
    Last Post: 04-02-2010, 06:34 AM
  3. Correct heat exchanger and exhaust color -1966 Normal
    By 304065 in forum Technical Info
    Last Post: 10-23-2008, 06:38 AM
  4. FS: 1966 911 Coupe and 1967 911 Coupe
    By mrbmw2002 in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 09-25-2007, 09:33 AM
  5. Q: correct radio and aerial for 67 911S?
    By Anthony67_911s in forum Technical Info
    Last Post: 02-17-2007, 03:11 PM
