Looking to purchase 986/996 core engines don't care condition or internal damage.
Tony
Tony
Tony Proasi
52 split window coupe
What is the going rate for a good running 996 motor, or a core for that matter?
Rick,
Running 3.4 or 3.6 cores range from 6k-8k, depending on mileage, cond, and seller. Buying one of these used is much like buying a hand grenade with a pulled pin. It's not if there's going to be a boom, it's when.
Cores generally range from 2k-4k.
Properly rebuilt engines run 11-16k. 11k gets you a "stock" rebuild with upgraded IMS on a good used block, 16k gets you increased displacement using LN Engineering re-sleeved block with new JE pistons. We stock 3.4/3.6 and 3.6/3.8 long blocks ready to go.
Tony,
We have tons of cores. Email me what you're thinking.
frank@beckseuropean.com
Just yesterday I passed on a 99 Carrera rollover. I know the day is coming when I have to work on these and I was going to buy it for training purposes. RR suspension was torn off so it wouldn't roll. To much of a hassle to deal with.
Porsche's troubled children for sure; at least the 996 series has some redeemable value.
Boxsters? 944's spawn.
BTW:
Have a complete '01 GT3 Cup motor available if someone wants to go that way.
Tony Proasi
It terrifies me that these discussions have become commonplace.
-Marco
TLG Auto: Website
Real world failure rates on the 996/986 engines is 4-8% by actual legal discovery -- because there was a class action suit. I've owned a couple 986s with no issues, and also have a 996-owning friend whose engine was destroyed by a failed IMS bearing. Discussing this stuff is a bit like discussing Area 51. Everyone has an opinion. Mine is that I'd be far more likely to install a factory bearing if I were doing preventative work than an aftermarket part that has not had the rigorous and widespread testing the factory part has.
techweenie.com
-Marco
TLG Auto: Website
