Results 1 to 7 of 7
Thread: 31mm TB in a 71 hot rod with a 3.2
    Jul 2012
    Cedar Park, TX
    Are 31mm hollow sanders bars too harsh with custom valved bilsteins for a 71 911 T with a 3.2L efi and 915? I am contemplating using these in my hot rod project. Chuck at ER is indicating 29mm, but I am looking at this as a budget thing.
    Jul 2006
    Corvallis, OR
    Listen to Chuck! I have 21mm front 28mm rear and it's just right. -Scott
    72S, 72T now ST
    Apr 2004
    35,000 ft
    I have a set of 31mm hollow tarett bars I'll make you a screaming deal on. just about 0 miles of use, they were taken out and swapped to coil overs.
    You don't state the weight (or rear weights at least). That is a very important parameter to determine proper spring rates. I have 22/29 solid with the car weighing 2000 pounds without a driver. Feels great to me. I wouldn't even mind stiffer. But ride is one of the most subjective car characteristics out there. Being 23, a lot of stuff in my car that I find comfortable is torture for older guys.
    Jul 2012
    Cedar Park, TX
    It's currently a stock 71 911t right now, but will be equipped as a hot rod for hill country driving and DE service. I am not sure of the weight. What does a stock 911t weigh? 2350lbs?
    It will have a 3.2L, most likely 993 HE's and M&K exhaust. Either 15x7 fuchs or 15x7 cookie cutters. No back seat. All a/c stuff will be removed. It will have RS carpet, Recaro's, stereo, RS door panels, I haven't decided on a roll bar or not. I haven't decided to go fg hood or keep with the steel hood. I will ad an front oil cooler and braided lines and tstat. It will have an fg duck tail most likely, as I have one already. I will add carrera brakes, rear trailing arms, front crossmember, and aftermarket sway bars.
    For the most part that will be it. I want to keep it simple and relatively light. These cars are so light to begin anyway. I may go carbs, which may save a little weight, but not much. I'm not going for light car since I will have a 3.2 with eventually hot cams and if EFI a SW chip. I don't think power will be an issue. I thought of going with the 901 if I take it easy in 1st gear that would save some weight, particularly on the rear.
    Then of course me at 215#.
    Sounds like 31mm will be too much for street duty.
    So, sounds like 31mm will be too much. I may have to put them on my 930 and go for some 29mm rears.
    Mine weighs about 2300 lbs right now.
    When I was really serious into auto-x and track, I used 23/31mm.
    Quite stiff.
    I have detuned down to 21/27mm and it is still worthy for auto-x and track....but much more comfortable for highway/around town driving.
    Mine has a big 3.6 pushing it, and this setup still has no trouble coping with the hp/tq that the engine puts down.
    -Doug
    2022 Carrera 4S Oslo Blue
    1977 Martini Edition 924
    1989 Lancia Delta Integrale 16V
    Jul 2012
    Cedar Park, TX
    Good to know Doug. Thanks. Will start work on the car hopefully next month and I will need to buy tb's. I believe I already have the front. I wish I had kept my 29mm bars that I just sold... It always works like that. The bars sat there for 2 years, I sell them, then I need them...
  1. FS: tarett engineering 31mm hollow rear torsion bars, almost new
    By blucille in forum For Sale: 911 Parts
    Last Post: 01-02-2013, 05:39 AM
  2. Replies: 0
    Last Post: 11-30-2012, 04:26 AM
