Hi, I just bought a bunch of Porsche parts off someone and not sure what year these doors and horn grills are from any help would be greatly appreciated.
Michael
Michael
Michael Rogers
Founder Nor Cal Vintage VW & Porsche Treffen and the Nor Cal Vintage VW & Porsche Swap Meet
1971 911T Targa/gold metallic
1969 912 Burgundy red
Rgruppe #833
https://www.facebook.com/Nor-Cal-Vin...9809110032975/
Doors are early 65-67. Remove the door panels and look for serial no. stamped on the door shell. If numbered they will be from a 65-66 car as they stooped numbering in 67 I believe. Horn grills a two hole, from later 66-67. One appears to be cut for through grill fog lights, can't tell if original or cut by previous owner.
Mark Erbesfield
1973 911S #9113301282
1957 356A #58648
1982 Toyota Land Cruiser FJ40
1977 Toyota Land Cruiser FJ40
1979 MB 450SL "Dad's old car"
2019 Cayenne "Wife's car"
My 67 doors are stamped
'67 911S
'69 911S
'70 911ST
'73 911T Targa Signal Yellow
'11 Spyder
Early S#1097, R-gruppe #
Mark Erbesfield
1957 356A #58648
Those look like 67 912 doors:
No rear stiffener in door pocket
Convex lock button
67 Winder
The "tell" is the diameter of the hole through which the latch protrudes, on the end of the door. What is the diameter in MM?
Eric,
My '67 S has the "pooched" stiffened door pockets.
Also chassis # stamps in doors.
Mark Smedley
'59 VW Typ I
'69 911T 2.7
'86 930
'04 GT3
'16 Boxster GTS
Thank you for the information, you guys are great. Where do I look for the chassis # stamps? I am posting some pictures of the doors to help further identify them. The one that does have a door panel seems to still have original wax pencil markings from the the factory.
Michael Rogers
Rgruppe #833
I buffed out the paint for the fun of it to see how good I could make it look, it appears to be the original black paint.
Michael Rogers
Rgruppe #833
I also have this air cleaner to identify, thanks for the help.
Michael Rogers
Rgruppe #833
Air box is most likely '66-'67...earlier would have more geometric shaped central filter cylinder and paper clip profile carb housings with definate passages between the three chambers. So your's is later shape but with three clips versus the wing nut flanges of '68 on.
My doors are stamped right in the center of the inner panel where the regulator and lock bell cranks attach. Last three digits.
Mark Smedley
'59 VW Typ I
'69 911T 2.7
'86 930
'04 GT3
'16 Boxster GTS
