Results 1 to 2 of 2
Thread: Widened my garage by 32"
    Senior Member BrentF's Avatar
    Sep 2012
    Toronto
    I am quite fortunate in that my garage measures 25' wide by 35' deep, which is enough to easily store 4 cars. Unfortunately there is an intermediate supporting wall at the back of the garage that makes things rather tight, so I decided to widen it by 16" on either side.
    Had to cut the concrete block walls using a diamond masonry cutting saw, and then create grooves that would accept the two pieces of 3/8" by 4" by 6" angle iron that would extend the structural I beam onto the remaining section of wall.
    Today I had a mobile welder come in to weld the 10" overlapping joint where the angle iron supports the I beam.
    Here's an idea of what I did. Pardon the mess as this work create quite the chaos not to mention clouds of dust.
    Here's a shot before the welder came and before the two 16" sections of wall were removed:
    Here's a shot after the welder and the two 16" sections of wall are removed.
    Tomorrow I'll remove the temporary posts as I am waiting for the non-shrink grout to fully cure, as it takes the load under the angle iron pieces:
    Apr 2011
    N.Calif., south of SF
    BrentF thanks for sharing. Nice to get the garage the way one likes it. Working on plans for one .... hopeful to break ground soon.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
  1. Garage find in our own garage versuch swt
    By Bivvv in forum General Info
    Last Post: 12-22-2021, 05:57 AM
  2. FS: Widened Steelies
    By tpweiss9953 in forum For Sale: 911 Parts
    Last Post: 10-06-2013, 07:49 AM
  3. 67S Widened Rear Calipers
    Last Post: 05-24-2010, 09:53 AM
