Thread: Problem with not functional dial light Blaupunkt US
    Senior Member Nicklasliljegren's Avatar
    Jul 2012
    Stockholm
    I've got a Blaupunkt Frankfurt US and the internal dial light bulb is not functional. I need some info about how to change the bulb and what type of bulb there is.
    Nick
    Jul 2011
    Chicago Area
    Post a picture of your radio and I could walk you through the procedure.
    Mike Fitton # 2071
    2018 911S Carrera White
    Senior Member ThomasTe's Avatar
    Jan 2005
    Denmark, Europe
    If I rembemer correctly, you just remove the upper cover on the radio, and remove the scale. Then you have access to the bulb. The bulb is 7 Volt /0.1 amp. They donīt make this version anymore. The one available in the same physical size is 12 volt / 2 Watt. That will not give you enough light, so donīt use one of those. I think the easiest way to get a 7V/0,1amp bulb is to find one from another old radio.
    Thomas
    1973 911S Targa
  1. 70 Targa interior dome light problem
    By 356robo in forum Technical Info
    Last Post: 11-25-2009, 11:50 AM
  2. headlight - break light problem
    By db911t in forum Technical Info
    Last Post: 04-17-2009, 05:27 PM
  3. WTB: Blaupunkt radio dial/button bezel
    By Kaleid in forum For Sale: 911 Parts
    Last Post: 05-14-2008, 04:50 AM
  4. Light Bulb for Blaupunkt Radio Face
    By bobmagyar in forum Technical Info
    Last Post: 02-16-2007, 01:06 PM
  5. Bosch CDI in '68 911- Alternator light problem?
    By 72tii in forum Technical Info
    Last Post: 06-19-2006, 05:42 AM
