Thread: Solid Door seal correct 45 degree cut and glue.6
    I am about to install the correct solid type seal on my 71, I know that I have to cut it in a 45 degree but I think it is not a clean cut, can any one show me the correct way to cut and glue this seal?
    Thank you.
    There are several pictures of this, do a search, it is not a miter joint, the vertical run butts up against the horizontal run.
    Ed is 100% correct. These are photos from a car that hasn't been on the road since 1980. The seals have dropped out of the slot but are original to the car. Passenger side and Drivers side.
    The one piece tubular seals that Porsche sells/sold are mitered. These were all you used to be able to get but are incorrect.
    There is a lot of information here if you use the search function.
    Early S Registry #235
    rgruppe #111
    I don't think thats the same solid type of seal that I post it.
    I have search for a picture of one install with no luck. If someone can post a close up picture of one install it will be great!
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Quote Originally Posted by Rino71 View Post
    Original seals on a 73S. Well, the 73S that won the national preservation award at PCA Parade this year....
    http://www.early911sregistry.org/for...l=1#post576959
    1969 S Coupe #761
    Early S Registry #1624
    The seal you are showing is the same as on my '69 911T and 912. Both are NOT mitered. Top horizontal run buts to the corner. The rear vertical run then buts up to the top rubber, as the other photos show.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
  1. Replies: 58
    Last Post: 11-03-2019, 05:12 PM
  2. Newer style door seal fit versus old style seal
    By EsGeht in forum Technical Info
    Last Post: 12-03-2009, 04:56 PM
  3. Help with door seal
    By RMartin in forum Technical Info
    Last Post: 08-24-2009, 05:19 PM
  4. Need Correct 915 Guide Tube Seal
    By Dezzmo in forum Technical Info
    Last Post: 12-02-2008, 11:58 AM
  5. Door top seal question
    By NTW in forum Technical Info
    Last Post: 09-17-2008, 11:56 AM
