Thread: Sprucing up/repairing the wiring harness
    Nov 2006
    S. F. Bay Area
    I'd like to clean, re-wrap and otherwise 'restore' my harness before re-installation. I've read (but can't find) a thread on this. It mentioned a certain shrink tube to cover the connectors as original. Also, does anyone have a source for the original type connectors?
    And, has anyone come up with a way to clean the connectors so that they are all shiny again? With or w/out having to replace the boot? Thanks all...
    Brian
    S Reg #1032
    Senior Member maspirito's Avatar
    Jan 2013
    lexington,kentucky
    You can get some wide vinyl tape without any adhesive on it on eBay fairly inexpensively.
    Nov 2010
    Harleysville, PA
    I am very interested since I need to do the same thing. I wiped it down with shop towels last weekend but did not want to use any cleaner, for fear of damage. Can you use a cleaner like simple green?
    Also, there was a long thread on the type of tape wrap to use a couple of months ago.
    Mark
    1967 911S - 306465
    1980 911SC
    2005 Carrera Cabriolet
    Terminals: Wurth sells the correct un-insulated "double crimp" terminals...and the specific crimpng tool you need, but......Wurth will not sell to private individuals. I have a local shop who the Wurth rep regularly visits, so I place an order with my friend at the shop. Snap On figured it out and now sells on their web...you's think the idiots at Wurth would figure it out.
    YnZ's sells the non-adhesive plastic loom wrap, although...my '67S has a lot of just adhesive "electrical tape."
    Shrink wrap is available everywhere but there is a wide range of quality....find an electrical supply house and buy in bulk.
    Wurth sells the correct vinyl harness sheathing, but in huge bulk lengths ($$). An outfit s SoCAl called Newco will sell short lengths of the correct sheathing...expensive per foot, but cheaper than 100 ft from Wurth.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    To clean up the terminals, and remove any corriosion.
    Mix some vinegar and salt, and scrub with an old tooth brush.
    Rinse in some water and bicarb, to neutralize the acid.
    Then spray with dielectric grease, to prevent corrosion/improve connectivity.
    Tony
    Feb 2012
    Kolham, Groningen, The Netherlands.
    Hi Brian,
    We can deliver anything you need, just contact us at info@kroonwireharnesses.com.
    Best regards from Holland.
    Gerard Kroon
    www.kroonwireharnesses.com
    Name:  foto kopie.jpg
  1. WTB: 914-6 wiring harness NOS
    By 9146racing in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 01-07-2014, 03:34 AM
  2. FS wiring harness '68 911 rhd
    By chasg in forum For Sale: 911 Parts
    Last Post: 12-26-2010, 07:53 PM
  3. WTB MFI wiring harness
    Last Post: 03-13-2009, 11:39 AM
  4. Wiring harness
    By ret9191 in forum For Sale: 911 Parts
    Last Post: 09-03-2007, 06:28 AM
