Results 1 to 8 of 8
Thread: Cable Guide Bracket
    Cable Guide Bracket
    Hi! The ear or ring cast on the differential side cover of my 911 (1971) is broken, it have worked fine with the simple aluminum sheet metal bracket fixed by one of the side cover nuts that the previous owner once made, but it really looks weak and I donīt trust it, so I would like to improve this. Is there any main strem solution to this? I don`t know if I like to spend all the money that for example the $440 Wevo transmission Side Cover for Magensium Die-Cast Casing with Bolt-On Cable Guide Bracket is. I want to buy or make an new adapter for this. Anyone that have some helpful input to this?
    I wouldn't want to try to weld on that magnesium. I guess you could mill a bolt-on piece from aluminum.
    Yes I also think some kind of bolt on bracket. First I thougt of repairing with zinc (remember I saw an article long time ago about that, found it again now, sorry itīs in swedish but that was for broken aluminum so I guess it doesnīt work for magnesium. Maybe useful for someone anyway: http://www.classicmotor.se/artiklar/...dning-med-zink ) Is there any ready bracket for this out there?, saw similar for the 915 tranny at pelican. Or do I just do something myself, diameter of the hole, how much clearance shall it be to the sleeve?
    Apr 2003
    Portland, OR
    I think you want a XT-206 Clutch Cable Bracket from WEVO. Cost? $68.
    http://wevo.com/Products/ClutchProdu...bleBracket.htm
    Harry
    Member #789
    2009 MB C300
    Jan 2011
    DFW TX
    That's for a 915...the 71 911 gearbox with its wacky push clutch need the guide tube mounted inboard of the side cover perimeter to keep everything lined up. A similar bolt on bracket would work. This one might work mounted bacwards... But the cable has to line up or there will be too much friction where the casing slides through the hole.
    My car has the aftermarket extended sleeve insert which helps guide the casing straight... I can take a photo if you need it, but this diagram should help. The cable guide is directly above the bottom side cover nut.
    Quote Originally Posted by M_deJong View Post
    ...the 71 911 gearbox with its wacky push clutch...
    wacky pull clutch
    Jon B.
    Vista, CA
    Jan 2011
    DFW TX
    Yes, you are correct, wacky push cable, pull clutch. What were they thinking??
    They were thinking it should last 4-6 years, then owner will buy new Porsche :)
    Jon B.
  1. Where to get a new cable housing for the hood release cable?
    By Sandwich Boy in forum Technical Info
    Last Post: 07-15-2009, 05:31 PM
  2. Which Guide Tube do I need?
    By Dezzmo in forum Technical Info
    Last Post: 03-30-2009, 02:04 PM
  3. WTB: 911/01 TOB Guide Tube
    By Neunelfer in forum For Sale: 911 Parts
    Last Post: 10-06-2008, 12:46 PM
  4. Price guide
    By surf in forum General Info
    Last Post: 05-05-2008, 06:54 AM
  5. 1971 Shift Rod Guide Bracket Mount
    By RTincher in forum Technical Info
    Last Post: 06-16-2006, 07:40 PM
