Thread: FS: 245 mm Fan Assembly 901.106.101.5R
    Feb 2003
    Los Angeles
    245 mm Magnesium Fan and Housing. Casting # 901.106.101.5R.
    This assembly will fit early 911’s from 1968 – 1983.
    No cracks or broken fan blades. It just needs a bit of clean up in a bead blaster.
    One of the fan blades has a very small dent mark, which I tried to capture in a close up photo. The fan blade is not chipped or broken.
    There is a small notch on the outside ring of the fan housing, see the photo below.
    See the photos below.
    Contact me via e-mail or PM.
    I would like $450 for the set, plus shipping costs and any Paypal fees. Or mail me a check to avoid the Paypal fees.
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
    Feb 2003
    Los Angeles
    Fits larger alternator
    This fan assembly came from a 1977 Carrera 3.0 engine. Same as the first gen 930 3.0 turbo engine.
    For this version fan assembly, the factory enlarged the alternator saddle to accommodate a larger alternator with a higher rating of 70 amps. See the chart below for reference.
    If you want the period correct look of an early 11 blade fan with the early style fan hub combined with the larger capacity of later 70 amp alternator, then this fan assembly is the way to go.
    Bert Jayasekera
    R Gruppe #167
    when these were introduced and the early alternators were used they installed a spacer to make up the difference between the deeper bore and the smaller alternator. it was a transition thing. gled
    Feb 2003
    Los Angeles
    Monday bump.
    Bert Jayasekera
    R Gruppe #167
    Feb 2003
    Los Angeles
    Thursday bump.
    Bert Jayasekera
    R Gruppe #167
    Feb 2003
    Los Angeles
    Fan assembly is SOLD.
    Thanks for everyone's interest.
    Bert Jayasekera
    R Gruppe #167
  1. WTB: 245 mm Fan Assembly 901.106.101.5R
    By Bert in forum For Sale: 911 Parts
    Last Post: 09-19-2013, 10:33 AM
  2. sway bar assembly
    By Bob Harriman in forum Technical Info
    Last Post: 03-08-2012, 01:10 PM
  3. wtb 911 pedal box assembly
    By cosley in forum For Sale: 911 Parts
    Last Post: 09-11-2009, 08:02 AM
  4. Some assembly required
    By 72targa in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 03-03-2007, 03:05 PM
  5. WTB-Ash Tray Assembly
    By ennisk1 in forum For Sale: 911 Parts
    Last Post: 01-23-2007, 06:05 PM
