Thread: 1971 porsche 911 pressure plate bolt torque specs
    Junior Member
    May 2013
    San Diego, California
    I'm restoring a 1971 Porsche 911e and need to know the torque specs for the pressure plate, and if lock tight should be used. If anyone has any idea or opinion on this I would love to know.
    my reference books list the torque value for the pressure plate bolts (8mm) as 18.4 ft lbs. (25Nm). I have not used lock tight on these bolts and I do not see the use of it mentioned in my reference books. I hope this info helps.
    regards,
    Al
    Al Kosmal
    the X-faktory
    Current projects; 69-911.5
    76S rat bastard---off to Germany
    1970 914-4...off to Wisconsin
    73 911X Cafe Racer...........(off to S.F.....now racing in Germany)
    66 912 ...off to France
    71E 9111200979 ( gone to Paris..then to Corsica)
    77S (off to NY)
    Early S #1240
    RGruppe #669
    www.x-faktory.com
    Paid Member # 1991
    Apr 2010
    Seattle, WA
    Just another data point: Hayne's (admittedly, not always the most authoritative source) lists 25 ft-lbs for pressure plate cover bolts. I could not find this spec in my factory service manual copy.
    FWIW - I like Blue Loctite for anything I'm not expecting to take apart for a long time and don't want to rattle loose. Although probably not necessary, I can't think of any reason not to put a small drop on pressure plate bolts and I hope someone who knows otherwise will chime in as to why. I would not use Red Loctite for anything on the engine other than rod bolts, as it is slightly short of welding strength. My .02.
    - MR
    18 lbs and no loctite. tight hardware won't rattle loose. Gled
  1. Torque Specs
    By 356robo in forum Technical Info
    Last Post: 03-30-2007, 09:56 AM
  2. Throttle Body Torque Specs
    By jayzoll in forum Technical Info
    Last Post: 05-01-2005, 06:35 PM
  3. aluminum lug nut torque specs
    By NiceT in forum Technical Info
    Last Post: 04-27-2005, 02:54 AM
  4. Steel Lug Torque Specs.
    By BradAndersonPHOTOWERKS in forum Technical Info
    Last Post: 01-10-2002, 09:23 AM
Tags for this Thread
