Results 1 to 10 of 19
Thread: 69E Tunnel Layout and Components
    Hi Guys
    Could i get some help with my tunnel layout.
    1) I think I have the items correctly identified per the attached photo, but would like some verification. I belive i solved #6 (accelerator cable) and #9 (speedo drive).
    2) I ordered what I thought was the grommet fo rthe wire harness and starter cable 999 702 051 50 but what I received clearly isn't going to work. Can someone help me identify what the part number I need for these going through the rear tunnel wall? I have one, but need another.
    3) Inside the RHS of the tunnel there is a conduit or inner tube. Is that for the main harness? Is there anything else that goes through there also? There is a wire for the emergency brake lever position, does that fish out a hole somewhere or does it split from the harness prior to entering the conduit?
    Appreciate your help for a new owner.
    Darren
Size:  100.3 KBName:  Grommets (2).jpg
    While I can't promise it's original, in my 1970T #6 is the throttle, #8 is the speedo cable, and #9 is the main harness. The others match what you have.
    Mike
    Mike Caterino
    1970 T targa
    Santa Barbara, CA
    restoration blog: mk911.blogspot.com
    Feb 2011
    Surrey, UK
    Agree with Mike. 9 is main harness and 8 is speedo.
    What you show is the large grommet for the starter cable. Don't think the main harness has a grommet, just a sleeve around the harness and a tight fit.
    Brake wire splits inside the centre console and then routes on top of the console to the handbrake out of the access hole for the shift coupling. There is a little curved depression in one corner
    Only the harness goes in the inner duct
    Mick
    Looking for help with route of charcoal canister lines from front to back. Thx
    Sorry.. This is for my 1973S
    Steel tubes through the tunnel with stubs at each end for the flex hoses to attach to.
    I am dropping engine tomorrow so may be more obvious then. If anyone has pics it will be appreciated.
    Ok. Engine out. See the 2 holes for charcoal canister lines which had plugs but when removed the plugs I don't see the steel lines. Have to dig deeper. How far into the tunnel are they? Appreciate advice. Thx
    Aug 2011
    north of the 49th parallel On Can.
    To go a little further into this thread, it would be nice to see some photos of all the correct original rubber boots & grommets that go to each of the outlet with a source to obtain them if some are not readily available.
    Hopper
    Quote Originally Posted by carguy5598@aol.com View Post
    Is this a U.S. market car?
  1. FS: MFI components
    By Rookie_912 in forum For Sale: 911 Parts
    Last Post: 02-25-2014, 05:22 PM
  2. 1972 Labelled Dashboard Layout
    By 72Group4 in forum Technical Info
    Last Post: 07-25-2011, 11:00 AM
  3. MFI layout and engine electricals?
    By teveo in forum Technical Info
    Last Post: 03-24-2009, 10:38 AM
  4. R GRUPPE European Car layout scanned
    By swbsam in forum General Info
    Last Post: 02-21-2009, 07:34 PM
  5. WTB H-1 Components
    By 50/50 in forum For Sale: 911 Parts
    Last Post: 12-30-2007, 03:46 AM
