Results 1 to 8 of 8
Thread: '69E Paint and undercoating questions
    Hi all-
    We're getting ready for final primer, paint and undercoating on the '69E. A few questions for the experts here:
    - I was planning on primer, SKS and then Rustolium satin black on engine compartment, trunk and underside. Is this right? (This is what I did on the Roadster and it's held up well)
    - Dash is flat black I think, what finish? Flat, satin?
    - Same black on hinges?
    - middle of trunk lid is under coated and then painted body color?
    - no under coating on engine lid, correct?
    Any other suggestions? Undercoat roof? Inside doors?
    Thanks a lot in advance!
    Cheers,
    Ron
    1961 356 Roadster Outlaw
    1969 911E ROW Coupe ‘Orangina’
    1968 911 SWT Burgundy Red project
    As per my very original '69 Karmann T:
    Agree with your plan for trunk/underside. Side note, The newer aerosol Rustoleum products are not very durable...VOC constraints most likely. Old school brush on is tough stuff. If you're planning on spraying consider the VHT epoxy in satin black, much tougher than new Rustoleum.
    Dash is satin, not flat...they age to flat which raised the question, but originally satin.
    Satin hinges, yes
    Trunk inside reinforcement, SKS and body color
    Engine lid is just body color, no ripply stuff!
    Roof got a glued pad, and doors were naked aside from seam sealer.....I would use some SKS inside the bottoms...maybe just a sound pad on the inside of the outer skin...you don't want to loose the "ping!"
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Oct 2010
    Southern Ca.
    Since your car is an E and probably not a Karmann , you should use 3M bodt schutz , it is rougher like the original . Also the underside of the car should not be painted black , only the wheel wells and the areas with body color overspray if you want to duplicate the factory .
    Quote Originally Posted by Richy View Post
    Just curious, why would you think this E car is not a Karmann? My 1970 E is a Karmann built in December of 1969.
    911 S Registry # 1054
    1970 911 E Coupe Signal Orange (#1414)
    1979 BMW 320i
    2001 Boxster S
    2003 Audi Allroad 2.7T Tiptronic
    2014 Jetta Sportwagon TDI DSG ( sold back to Volkswagen)
    2015 Allroad 2.0 TFSI
    Oct 2010
    Southern Ca.
    My mistake . I believe Porsche did not make the E 's until 1971 .So disregard the 3M note .
    There were 911E models built and sold in 1969! When they went to the B series in '69 they went with the "plasticized" under coating system, and there is no difference between Karmann and Reutter (Porsche) under coating...Wurth SKS for both. Subtile structural differences, yes, but not undercoating.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Senior Member mimimemegna's Avatar
    Nov 2007
    Sanremo Italy
    Quote Originally Posted by smedley View Post
    My 911 E MY 69 was built in october 68 and sold in november 68!
    Maurizio G.
    Early S Registry member #1253
    1968 MY 1969 Light Ivory 911E
    Senior Member 210bhp's Avatar
    Feb 2004
    Scotland
    Eve, the first ever E was built in June 68.
    Mike
    RS#1551(sold)
    67S
    Early S reg. #681
  1. 72 paint questions
    By jpnovak in forum Technical Info
    Last Post: 11-05-2013, 05:48 PM
  2. Questions on primer and paint...
    By StephenAcworth in forum Technical Info
    Last Post: 09-20-2013, 07:57 AM
  3. Replies: 4
    Last Post: 11-24-2012, 03:31 AM
  4. Paint help questions...please
    By John Straub in forum Technical Info
    Last Post: 11-08-2012, 05:36 PM
  5. A few questions regarding paint and undercoating
    By emnemn in forum General Info
    Last Post: 03-09-2011, 05:21 PM
