Results 1 to 7 of 7
Thread: Rear caliper brake line hookup (67)
    Nov 2006
    S. F. Bay Area
    Have run all new brake lines/hoses throughout car, but the rear caliper connection escapes me. The hard line arrives near the caliper at an angle perpendicular the the banjo bolt hole. Unfortunately, the parts books offer no picture or description of this area. How do they connect? Any photos available? Thanks
    Brian
    S Reg #1032
    If memory serves me (without looking at a car) there is no banjo for the rear caliper, brake line threads straight into the caliper.
    Ed is correct, I just made up some new rear swb lines last week using the old ones as a pattern - there's a "loop" in the line to orientate the fitting straight into the caliper. I can send you the old lines if you'd like or a photo later today. Stoddard (and others?) sell a form-your-own brake line kit to do all lines in the car.
    John Schiavone
    Connecticut
    Here's a photo of the left side, caliper removed for rebuilding. Left is a mirror image.
    John Schiavone
    Connecticut
    Nov 2006
    S. F. Bay Area
    Excellent! Thank you both.
    If I had bolted up a caliper first, it might have been apparent. Thanks for the assistance, as always.
    Brian
    S Reg #1032
    Atlanta, GA
    John, what year is your 912 bc the 65 I just did brakes on is quite different than the pic you show. I'm not sure off top of my head when the change occurred, but the early ones are more like an "L" than the loop you show.
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    It's actually a December build 65 911. I'm working with the lines included in the kit, which may be a bit longer, but I used the old lines as a template (assuming they were original).
    John Schiavone
    Connecticut
  1. FS - New Rear M Caliper Brake Pads (Hawk, Porterfield)
    By tom1394racing in forum For Sale: 911 Parts
    Last Post: 02-21-2010, 02:17 AM
  2. rear brake caliper
    By Francois Duval in forum Technical Info
    Last Post: 11-30-2009, 05:26 PM
  3. Broke metal brake line left rear
    By B D in forum Technical Info
    Last Post: 05-20-2005, 08:07 PM
  4. Source for Brake line, S Caliper?
    By caproader in forum Technical Info
    Last Post: 09-27-2004, 05:31 AM
  5. brake caliper refurbishing
    By thback in forum Technical Info
    Last Post: 10-23-2001, 02:11 AM
