Results 1 to 7 of 7
Thread: Which inserts to Boge strut assembly
    Senior Member Nicklasliljegren's Avatar
    Jul 2012
    Stockholm
    My 911E 1970 have the Boge front strut assemblys and I'm planning to change the inserts. Which is the best insert Sachs, Bilstein or Koni?
    Nick
    I think fitting a Koni is difficult as the shape of the legs are different there is no means of radially locating the bottom of the inset in the housing.
    We have fitted Koni Sport Inserts which adjust from the top. These have a small diameter post on the bottom of the insert and they are a few millimetres to short to be locked in place by the gland nut.
    If you make a slightly domed spacer with a central location you can lift the insert so it will lock and provide a radial location to prevent swash.
    I would fit a Bilstein to Boge insert as it should just fit and clamp in place.
    Jul 2012
    Stockholm
    Chris,
    Thx Nick
    Feb 2003
    Corpus Christi, Texas
    The Koni 86-1647 is the direct replacement for the early Boge Strut:
    http://www.paragon-products.com/Sear...Search=86-1647
    Unless you need external rebound adjustment or stiffer valving, this is the Koni to use.
    Jason Burkett
    Paragon Products
    Early 911S Registry #428
    R Gruppe #375
    1973 911S
    1972 911T
    1974 914 Limited Ed. Blk/Yellow
    1989 944 Turbo
    1993 968 Turbo RS
    1967 Shelby GT500
    1968 Shelby GT500 Conv.
    2010 VW GTI, Daily Driver
    May 2005
    Oroville, CA
    I tend to agree with Jason.
    Unless something changed... years ago, we put in dozens of these and they fit just fine.
    H
    Last time we bought these parts and fitted them to a Boge leg they didn't clamp in as they came up short by 3mm and I didn't like the basic fit.
    They also had some radial clearance between the insert and the body and nothing in the bottom of the strut to locate the 'peg' so the could float, hence the adapter that we made.
    Feb 2003
    We've sold this part number for 20 years without issue.
    Jason Burkett
    Paragon Products
    R Gruppe #375
    1973 911S
    1972 911T
    1989 944 Turbo
    1993 968 Turbo RS
    1967 Shelby GT500
  1. Replies: 1
    Last Post: 02-02-2014, 09:22 AM
  2. FS: NOS SWB Boge strut inserts
    By typ901 in forum For Sale: 911 Parts
    Last Post: 09-13-2011, 06:24 AM
  3. FS; Koni strut inserts, pn 86-1647 for Boge strut housings
    By m1franck in forum For Sale: 911 Parts
    Last Post: 03-08-2010, 09:19 AM
  4. NEW Boge Gas Strut Inserts for 69-73
    By greggearhead in forum For Sale: 911 Parts
    Last Post: 08-13-2009, 05:00 AM
  5. NOS Koni 65-68 Boge strut inserts FS
    By 66S in forum For Sale: 911 Parts
    Last Post: 02-06-2009, 02:19 AM
