Results 1 to 7 of 7
Thread: Vin nos
    Vin nos
    Is there anywhere to check the vin nos of early cars - want to verify a 1973E vin number.
    Nov 2012
    Amelia Island, FL
    9113200001-9113201366 coupe or 9113210001-9113211055 targa... Or do you mean verifying the body number under the radio matches the chassis numbers I listed?
    If so I don't know where to do this but would like to hear from someone who does.
    Hello in the Canary Islands this vehicle was registered. I wonder if it was the last of some series or similar?
    autoresponse
    Senior Member matteo68's Avatar
    Jul 2021
    Wootton, Woodstock, UK
    Hi
    First post here, as a brand new member on the board. I am in the process of importing a 1972 MY 2.4T Coupe from California to be an ST tribute car. The chassis number is 9112102176 and I believe it is non-matching numbers and there is no COA available, but that is not a major problem as I am going to be putting a 2.8l twin-plug engine into it. Can anyone confirm what the factory specification and engine and gearbox numbers should be however?
    Thanks.
    Lightbulb
    Your '72 T coupe VIN falls within the numbers:
    9112100001 - 9112102931
    Engine:
    6120001 - 6124478 - type 911/51
    Cant help on the gearbox...
    Hope this helps... and welcome to the board...
    Oct 2008
    Burford, ON, Canada
    I can get the equivalent of a CoA if that is what you want.
    Jul 2021
    Thanks, that would be great if you can
