Thread: Opportunity Knocking :)
    Mar 2003
    Santa Monica
    My '73 S has a damaged crank and rod. So replacements are called for. Is this an opportunity to upgrade anything, like better lighter rods or ...?
    Early 911S Registry #224
    911S Targa 1973
    356B Roadster 1962
    Lighter rods, Titanium valve spring hats, bigger pistons and cylinders if you really want to get serious. JE makes some lighter weight pistons now using a new design so even if you stay stock diameter it would be lighter.
    Lighter is triple good in the engine because it is reciprocating weight that limits engine speed+fast the revs build, and engine longevity (lighter means less stress on bearings, etc.). In addition it is weight that comes off the far back of the car, improving weight distribution a lot.
    Nov 2002
    Fremont, CA
    You could see a very marginal benefit by doing a lot of work and spending a lot of money. Porsche did a good job. Find a std/std crank and a new set of ARP rod bolts.
    scott kinder
    kindersport@gmail.com
    Registry #614
  1. Interesting opportunity for body and paint team
    By Eminence Gris in forum General Info
    Last Post: 08-03-2012, 07:23 AM
  2. Knocking sound in steering (SWB)
    By Davz912/911 in forum Technical Info
    Last Post: 08-02-2011, 07:35 PM
  3. Esses Advertiser Opportunity - Classic & Speed Parts
    By 72targa in forum For Sale: 911 Parts
    Last Post: 09-11-2009, 05:23 AM
  4. Will Build to Suit: custom opportunity
    By TRE Cup in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 06-14-2006, 04:52 PM
  5. Right Front Knocking Noise
    By TripleR in forum Technical Info
    Last Post: 03-01-2001, 06:32 PM
