Results 1 to 9 of 9
Thread: WTB: löbro drive shaft flanges
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    need two pair of löbro drife shaft flanges(the inner side --gearbox side) the 67` and the 68` version.
    + the correct center bolt(torque to yield bolt) and caps.
    thanks
    franz
    Aug 2009
    SF Bay Area
    Do you want the 67 version or the 68 version? They are very different.
    Jim
    May 2013
    AUSTRIA (tu felix)
    yep i know...i need both versions.
    May 2010
    Louisville Ky
    PM sent........
    70E Albert Blue
    Member #1906
    Aug 2009
    SF Bay Area
    Here you are. Both types of flanges and all the assorted bolts and washers, as requested
    Jim
    Restoration newbie.
    Jun 2007
    San Francisco
    If those bolts are torque-to-yield should they be reused?
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Early CV Flange Bolts
    Hi Jim, minor correction to your parts photo:
    Early axle flange bolts (65-67, both Nadella & Lobro) did not have wide portion under head to center washer; those are 1970's bolts. Photo below of two early versions...
    Jon B.
    Vista, CA
    May 2013
    AUSTRIA (tu felix)
    thanks jon b you are right my 65 and the 67 have the bolts you posted....jim i do have the bolts with the tip so this ones i do not need..would be cool if you find the ones on jon b s pic and put it them in the box + the ones on to the left on your pic .... just to have my collection complete.
    Aug 2009
    SF Bay Area
    Jon
    Thanks for correcting me. I just went and grabbed the 2 shiniest bolts I could find in the bin for the picture.
    Would I have discovered my brain fahrt before sending them to Austria? Probably not.
    Thanks for saving me an expensive and embarrassing mistake!
    The 2 correct bolts are on the right and have been placed in the box.
    Ciao
    Jim
    Jim
  1. WTB: 901 gearbox drive flanges
    By gregary in forum For Sale: 911 Parts
    Last Post: 03-21-2014, 12:29 PM
  2. 73 drive shaft??
    By JLDAMIANS in forum Technical Info
    Last Post: 03-09-2013, 05:11 AM
  3. Nadella drive flanges
    Last Post: 03-14-2012, 06:03 PM
  4. FS Mag Fan housing and Nadella 1/2 shaft flanges
    By gilbert911 in forum For Sale: 911 Parts
    Last Post: 03-20-2011, 11:24 AM
  5. WTB Nadella axle drive flanges
    Last Post: 12-29-2005, 05:11 AM
