Nice, wish it was mine. Decent price.
http://sfbay.craigslist.org/sfc/ctd/4135725323.html
Cheers.
-Kav
Cheers.
-Kav
VIN = 307410
Eng# = ?
Trans# = ?
. . . This extremely well sorted SCCA spec race car was build to compete in the SCCA GT-3, PCA Club Racing GT-5 and RMVR CP classes and was very competitive winning an SCCA championship in 1999 . . .
. . . The Car was professionally built by On The Edge in June of 2000 and has been maintained most recently by Stewart Krum of Schatz & Krum. This vehicle has a legal 2.0 Litre engine that has been completely rebuilt with all new internals and has had less than 300 miles since the rebuild, so fresh it still needs to be broken in. New internals and components include Molly pistons and cylinders, Pauter rods, oil passages in case, 69 ''S'' heads with big valves, Carrera chain tensioners, 10.6 to 1 compression, Mobil 1 15/50 oil, rebuild Weber 40 IDA carbs with race mods, brand new 901 transmission (1 race old), 904 limited slip differential, custom short gears with tall first:CFJOU and big brake master cylinder . . .
. . . The Chassis was stripped of all undercoating and refinished, absolutely no rust anywhere, 21 front and 29 rear torsion bars, new bilstein shocks, Weltmeister front and rear asjustable sway bars, all plexiglas windows, new flow master exhaust with heat coating, full Race-Tech cage with 3R custome bars and seat back brace, aluminum door skins, 2 Corbeau ProSport Carbon Fiber FIA 10.8 seats on sliders, Schroth Pro 5 point cam lock belts, dry-cell light weight racing battery, Smart Racing oil tank, Peterson in line oil filter, headlight buckets with air ducting and mesh grills, new factory oil cooler on engine, fire system, MSD soft clip limiter (8,00 RPM) Auto meter tell tale tach with memory, oil pressure/alternator warning lights, 2 exhaust gas temperature gauges, fuel pressure gauge, hop lap timer, pre wired for radio, 15 gallon fuel cell, triangulated camber truss (polished), new shift coupler, corner weighed and aligned, ''S'' front spliter, RSR hood and trunk hold down pins, SFI roll bar padding, engine hour meter . . .
. . . The vehicle comes with many extras/original parts, service records, receipts, track day data and photographs documenting the build. There is also a twin axle open car trailer with utility box and tire rack that can be purchased seperatly. VIN#: 307410 Chassis #:307410 . . .
. . . To see more photographs of this vehicle feel free to visit us at LuxMotorcars.com . . .
Phone#: 916.455.4556 . . .
(Not mine)
