Results 1 to 10 of 19
Thread: 60's era Metallurgy
    60's era Metallurgy
    Has anyone heard that the late 60's era Porsches were made out of Italian steel that is prone to becoming brittle over time? I haven't seen this happening to my car, but I heard it is an issue that exists beyond the rust from a guy in Reno. I was trolling the threads, and it doesn't look like it has come up as an issue. Any tribal knowledge on the subject?
    That sounds like the punch line of a joke...
    The steel is certainly not precipitation-hardening steel, as that has only become widespread recently. So it won't get brittle over time unless you are stressing it too much and causing it to work harden.
    Now if you want to talk about rust over time, that is a different matter.
    911s must be German steel.
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    yes i have expierienced that the steel gets brittle on early 911...this also happened to some nos parts i have here in my shop....so i also think that the steel is ageing...
    sheet metal used for stamping car body parts is a special steel(sondertiefziehgüte--thats the german word) and it can not be stored for long time cause it looses its positive charactaristics for forming within weeks after production. i assume this process slows down but never ends...im not a metallurgy geek ....so just dangerous half knowledge.
    but i doubt that this is a safety issue .....so far
    Buy a Corvette.
    Early S Registry #235
    rgruppe #111
    May 2013
    AUSTRIA (tu felix)
    or a A110
    Jan 2011
    DFW TX
    I always heard Karmann invented rust and licensed it to the Italians...
    Were those parts plated?
    I agree that nowadays steels are designed to harden over time (but only at elevated temperatures) or to have retained metastable phases that convert after cold-working or heat treatment, but I believe that in the 1960's it was mostly just plain steel.
    My car is made of German steel and I prove it here: http://www.early911sregistry.org/for...ts+restoration
    Jul 2008
    South Florida
    Aside from the various forms of oxidation, metals don't "age". The only thing that makes steel brittle is excessive cold... we're talking double digit
    negative Kelvin numbers here, not winter temperatures. If of the same metallurgical composition, old steel or new will have the same tensile and
    compressive strength. Excessive heat is the killer, altering the molecular alignment of most metals... any car that's been in a fire should be scrapped.
    Sitting for 50 years in a dry barn? No problem.
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by Bullethead View Post
    o.k. metals dont age...but metal used for a 86 is different from the one a 67 is made out of..it is easier to form and softer. and is not cracking as fast...
    what about magnesium alloy? i would not go for a hot ride with my 917 even on nos rims.... what is this process called that makes magnesium brittle?
  1. FS: Porsche lighter 60's
    By Andy 74 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 07-28-2013, 05:46 PM
  2. FS: Porsche lighter 60's
    By Andy 74 in forum For Sale: 911 Parts
    Last Post: 05-07-2013, 08:38 PM
  3. FS: Porsche lighter 60's
    By preS in forum Other Porsche Passions
    Last Post: 05-28-2012, 12:33 AM
  4. FS: Porsche lighter 60's
    By preS in forum For Sale: 911 Parts
