I have a 1968 911E engine complete with mechanical fuel injection that I obtained in a deal when I purchased a 1969 911 incomplete roller that I plan to build into a vintage racer. The engine had no history at all but looked to never have been opened and as such I wanted to know if the MFI worked. I successfully installed it and low and behold it actually runs and idles!!
I assume it is a tired engine and could use a rebuild, the oil return tube seals leak oil and the hot leak-down test gave me numbers in the 15-20% range. Good news is the MFI works.
I have decided to build a 2.7 with Webers as I have a good later year core, so this package is for sale
details, it's a 901/11 16299
serial number 6298020
I can send pictures and I may even figure out how to send a video of it running,as it's still in the car.
what do you think it's worth?
I and engine are located in Vancouver Canada
