Results 1 to 9 of 9
Thread: Zuffenhaus "RS" wheel
    Senior Member Aldo's Avatar
    Dec 2007
    Austin Texas
    Just installed this new RS replica steering wheel from Zuffenhaus today. I'm very impressed with it- it's a very high quality piece and looks an feels like you would hope it would. I don't know how they're built/sourced but it's even stamped VDM. I wish I'd taken detailed photos before installation but didn't. It goes with the R seats so much better than the big, skinny rimmed stock wheel did.
    Alan Domme
    Austin, TX
    '68 912 coupe
    '16 VW Golf R
    Early 911S Registry #1361
    912 Registry
    Port Macquarie, Australia
    Looks great! I have something similar on order...
    John Forcier
    EarlyS #1987
    Restoration Saga
    Zuffenhaus "R" Wheel
    I had their 911R replica mounted for several years --- also, very nice
    (Only replaced it 'cause I found a 'period correct' wheel)
    Senior Member Warm Tea's Avatar
    Oct 2013
    Long Beach , Ca.
    What size hub were you running with the "R" wheel and would you prefer the 60 over the 80mm any preference info would be great. Also did the mounting hardware come with the wheel or was it outsourced. They are great looking wheels for sure and I may step up shortly
    Philip
    Long Beach
    69T Sporto just getting started
    69 Bahama T
    S Reg# 2753
    Senior Member boba's Avatar
    Jul 2006
    DFW
    I have the 80mm on now, started with the 60mm. A lot depends on how tall you are. The 80 gives a bit more clearance under the wheel for your legs, enter and exit. As I sit far back I do like the extra length. Hardware is included.
    65 356SC Dolphin Gray
    66 912 Green
    69 911E Tangerine
    72 911T GP White
    72 911T Aubergine
    72 911T Lilac
    72 911S Black (voodoo)
    90 964C4 Black Targa
    94 964C2 Black Coupe
    08 GT3 Speed Yellow
    Oct 2013
    Long Beach , Ca.
    boba,
    Thanks for the input, I'm only 5'10" so getting in/out is not too much an issue I will probably go with the 80mm hub as well. Great looking interior BTW!
    Philip
    69 Bahama T
    S Reg# 2753
    Senior Member platas's Avatar
    Jun 2005
    Spain/Houston
    Aldo, looks good, what seats are those ?
    San
    53 Pre A, 65 356
    70 914/6 GT
    65 912, 67 911
    71 911 Targa,72 E Tara, 73 911 Targa
    70 911 S,71 911 S,70 911 T,
    71 911 T, 72 911 E ,73 911 T
    74 911 Coupe
    74 911 Targa
    1972 RennSport Bus
    Early Reg # 771
    Quote Originally Posted by Warm Tea View Post
    . . . What size hub were you running with the "R" wheel and would you prefer the 60 over the 80mm . . .
    Hey, Phillip . . .
    I started-out w/ a 60 mm, and I fit OK but what really made a difference was going w/ a smaller diameter wheel. I'm ~6'5" so 'clearance' is always an issue.
    Regarding spacers, just keep in mind that, while the wheel will move out --- the turn-signal/wiper wands stay put . . . so any spacer will increase the distance your fingers'll need to span to reach some of the controls
    HtH . . . and welcome to Our Little Corner
    Dec 2007
    Austin Texas
    Platas- The seats are from Vintage Seats and are the "R" model. I highly recommend the seller and the seats!
    Alan Domme
    Austin, TX
    '68 912 coupe
    '16 VW Golf R
    912 Registry
  1. FS: Special Extended Hub 380mm "RS" "RSR" Thick Grip Steering Wheel
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 06-06-2014, 12:47 PM
  2. FS: Special Extended Hub 380mm Thick grip "RS" "RSR" steering wheel
    Last Post: 10-30-2013, 01:47 PM
  3. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 03-17-2012, 07:56 AM
  4. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 02-18-2012, 09:24 PM
  5. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 01-24-2012, 01:59 PM
