Results 1 to 9 of 9
Thread: Sill question........?
    Hello,
    I've been looking at various early 911 cars and noticed some cars have holes along the sill areas and some do not. My particular car which is a 69t has two round holes and an oval hole near towards the door hinge area.
    Could some one tell me the difference why, maybe my car has had replacement sills at some point? I'm not sure.
    Thanks for your help, please see picture.
    Lee
    Can anyone help?
    I've seen the three holes on 68 SWB cars but don't know if they follow through to LWB cars.
    Anyone have any ideas?
    Thanks lee
    Oct 2010
    Stockholm/Sweden
    Lee, I can confirm them on SWB cars, I have the, on a -66 912.
    Porsche 935 DP1 Zirkelbach
    930/10
    Resale red
    Porsche 911, 1971
    2.5L on Webers
    Silvermetallic
    Jun 2012
    London, Ontario, Canada
    3 small holes, much closer to the seal mounting lip on a '73 LWB. Mine are definitely original.
    Early 911S Registry # 2395
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Lee,
    The rectangular hole is standard, it usually has a small piece off steel held in place with seam sealer. The new panels don't have this indentation.
    I haven't seen the large holes before. But MY69 had S sill trim, maybe it is a rubber sill trim thing?
    The S trim is held in with those little plastic rivets, and where fitted you will have small holes only, close to where the door seal fits, as in the photo above.
    Tony
    Thanks guys,
    Lee
    What I believe were the original outer rockers on my '70 had the same larger round holes you show. My understanding is that these allowed application of cavity wax or whatever minimal rust-proofing the cars got. The little holes shown by NorthernThrux are for holding the inner edge of the aluminum 'S' sill plates down. (OT, but I thought these were supposed to be sheet metal screws - never heard of the plastic rivets Tony mentions.)
    Mike
    Mike Caterino
    1970 T targa
    Santa Barbara, CA
    restoration blog: mk911.blogspot.com
    Jun 2012
    In the PET it says sheet metal OR plastic expanding rivet. Often the Carrerra 2.7 numbers apply to the S models for the interior trim, but I'm not sure which was on my car to be honest (it's an S as noted). Numbers below are from the pdf of the PET. I have an original PET binder and will check it too.
    28 900.143.040.02 B2.9x9.5 (20 needed)
    29 999.591.550.40 (72-) CARRERA 2.7 Expansion rivet (20 needed)
    Jun 2012
    In the real PET binder it says
    45 900.145.041.00 Lens head countersunk screw B 3.5 x 16 DIN 7983
    50 999.591.526.40 Plastic rivet for 911S
    So it looks like the S and RS used plastic and the rest used sheet metal. Different strokes for different sills.
  1. FS: door sill inner right 911.501.124.03 NOS
    By typ901 in forum For Sale: 911 Parts
    Last Post: 10-15-2017, 05:33 PM
  2. WTB: LWB window sill trim
    By lexatola in forum For Sale: 911 Parts
    Last Post: 11-23-2013, 02:33 PM
  3. Sill detail on 65 911
    By Alan B in forum Technical Info
    Last Post: 05-24-2008, 02:41 PM
  4. Question re fastening the aluminum door sill plates
    By wolfturbo in forum General Info
    Last Post: 01-04-2005, 07:41 PM
  5. Rivets for door sill?
    By 911pcars in forum Technical Info
    Last Post: 12-25-2004, 10:04 AM
