Thread: Koni shock rebuilding services?
    I did a search and found several leads from 2009...just checking to see if there is something more current re a source/recommendation for rebuilding the front struts on my 73 911 or is this a DYI project if the parts are available to a consumer? Thank you!
    Lightbulb
    Mac,
    Try our friend Jason at Paragon first .... then you can always call Koni
    http://www.paragon-products.com/default.asp
    http://www.koniracing.com/
    Hope this helps......
    Recently a friend of mine told me Koni did his 356SC shocks for him. Awaiting the contact information. His are "Koni Blue" and
    the work was very nice.
    Tom
    Early S Registry #235
    rgruppe #111
    Feb 2003
    Corpus Christi, Texas
    Your best bet on this application is just to buy the correct inserts for whatever strut you have and install them yourself. Easy to do. If you have Boge strut housings (black) then you'll want this insert:
    http://www.paragon-products.com/prod...ni-86-1647.htm
    if you have original Koni housings (red) you'll want:
    http://www.paragon-products.com/prod...ni-86-1638.htm
    and finally, here's a tech article that addresses installation:
    https://www.paragon-products.com/kb_results.asp?ID=5
    Jason Burkett
    Paragon Products
    Early 911S Registry #428
    R Gruppe #375
    1973 911S
    1972 911T
    1974 914 Limited Ed. Blk/Yellow
    1989 944 Turbo
    1993 968 Turbo RS
    1967 Shelby GT500
    1968 Shelby GT500 Conv.
    2010 VW GTI, Daily Driver
    Thank you....Paragon it is...just need the Koni 'inserts' for the front!
  1. Koni Shock ID
    By Haig Haleblian in forum Technical Info
    Last Post: 02-10-2010, 12:47 PM
  2. Rebuilding early Koni shocks
    By Neil '67 911S in forum Technical Info
    Last Post: 04-19-2009, 08:05 AM
  3. FS: Koni Shock
    By John Straub in forum For Sale: 911 Parts
    Last Post: 02-22-2009, 02:07 PM
  4. Front Koni shock covers
    By curtisaa in forum For Sale: 911 Parts
    Last Post: 07-21-2008, 01:51 PM
  5. Koni shock replacement
    By adam912 in forum Technical Info
    Last Post: 01-08-2007, 09:12 AM
