Page 7 of 11 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 106
Thread: The starting of the stripping process
  1. #61
    May 2008
    Sydney
    Hi Clyde,
    Yes i worked out it was a 85 litre plastic tank, seems if i get stumped i often go to the main forum and post a few questions. It is probably due to the main forum having alot more viewing than our regional Australian forum. Glad you agree about the colour, i think gold is an awesome colour too, and it is the original colour so that what i am taking it back to. I am aiming to keep the car moving along through the restoration even if its slowly at times, and by all means feel free to add your two cents worth as my project progresses along. I do have a vision for the restoration and the finally completed car, but i am always open to others experience as i work through it.
    How are your ongoing projects/cars coming along ?
    cheers
    clayton
    Clayton Shipard
    Sydney, NSW Australia
    1972 911 2.4S
    2000 Boxster S
  2. #62
    May 2008
    Sydney
    I was chatting to a fellow early911S registry member and he managed to get a listing of the options that came with my car.
    A massive thanks to San, I really appreciate the help from a fellow member. For now this will do until i get my COA.
    Heres the option info for my car.
    VIN 911 230 1384
    engine 632XXXX
    gearbox not listed
    color 8888=goldmetallic
    interior 13=leatherette black/Pepita
    dealer 114=Glöckler,Frankfurt
    invoice June'72
    options 258=headrest left/right
    409=sportseat left/right
    426=chrome trims on wheel housings
    427=rear embellisher
    432=additional highbeam lamps over bumper
    499=fuel tank 85l
    568=colored windows
    650=sliding roof
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
  3. #63
    Senior Member platas's Avatar
    Jun 2005
    Spain/Houston
    Clayton, no problem at all.
    San
    53 Pre A, 65 356
    70 914/6 GT
    65 912, 67 911
    71 911 Targa,72 E Tara, 73 911 Targa
    70 911 S,71 911 S,70 911 T,
    71 911 T, 72 911 E ,73 911 T
    74 911 Coupe
    74 911 Targa
    1972 RennSport Bus
    Early Reg # 771
  4. #64
    Clayton
    Wow highly speced car
    So does 432 mean Cibies wired into headlight circuit?
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
  5. #65
    May 2008
    Sydney
    Thanks Clyde
    The car is missing the 432 option components but i believe the picture below shows the high beam lights, which were meant to be on it. And i think you are correct.
    it was also missing the 427 option components which is the rear muffler skirt as per the picture below.
    So thats just a couple more parts to source and find to complete my restoration.
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
  6. #66
    No thats not what I thought they were.
    Those are Hella 118 fog lights although you could get those in driving lights as well.
    I owned a tourist delivery car that had the bigger cibbies wired into the headlight circuit and they only came on as high beam lights
    as the list says high beam lights over bumper that doesn't mean fog ligts to me. I am not familar with all the codes though and it could be the description is wrong.
    Clyde Boyer
  7. #67
    May 2008
    Sydney
    Hi Clyde,
    I am only guessing these are the driving lights.......described by the code i found the above picture i thought was the lights. The codes are from a a thread on this registry for 1969 - 1973 911s'
    http://www.early911sregistry.org/for...t=option+codes
    M 432 : Quartz-iodine long range lamps, white. Above bumper. (Through-the-grille driving lights)
    Do you have any pictures of the lights you are describing ? As i too am not totally familiar with the codes either.
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
  8. #68
    May 2008
    Sydney
    Thanks Hugh.......(i have pasted the below which was a reply to another post)
    here you go Clayton
    they are LIKE the fogs you have shown but are long range driving light lenses instead of the fluted fog lends to give a wide flat light spread
    ( from the 71 - 73 options booklet)
    PS they are around but much rareer than the fogs
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
  9. #69
    Yes I and another Melbourne owner both acquired a set each last week at great expense to the management.
    Hella 118 driving lights to be more precise. They are quite rare as Hugh says but as we have just shown also available from time to time.
    Clyde Boyer
  10. #70
    May 2008
    Sydney
    by the way are you sure that the 85l tank was option 499?? I have an 85L tank (came standard in my car) but the options book shows the code as 424 - see below. That does not mean that the number changes but the book is suppoeed to cover 911T E S and 914 from 71 to 73
    I added in pics of a couple more of your options just for completeness
    Hugh Hodges
    73 911E
    Melbourne Australia
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
  1. Magic rechrome process
    By adam912 in forum Technical Info
    Last Post: 10-02-2012, 02:24 PM
  2. Stripping, dipping and Ecoating
    By nick-moss in forum Technical Info
    Last Post: 08-05-2012, 07:38 PM
  3. Stripping Undercoating Need Ideas Please
    By FHernand in forum General Info
    Last Post: 11-26-2006, 10:01 AM
  4. New PCA COA process
    By pu911rsr in forum General Info
    Last Post: 10-20-2006, 04:53 AM
  5. Signal Color Process
    By rsr1975 in forum General Info
    Last Post: 01-31-2006, 07:19 AM
