Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: SWB seat hinge rebuild question
  1. #11
    Senior Member eaton's Avatar
    Nov 2009
    DC/Montana
    I did it with a bolt in the jaws of a set of vice grips. Put the bolt in the loop of the spring and use the vice grips to pull it around and tight. Wear eye protection. When those springs take off, they take off like a bullet.
    '66 912 with a 2.2
    '62 Lotus Seven S2
    '66 Lotus Elan
    '63 Karmann Ghia convertible
    '76 Alfa Spider
  2. #12
    was the spring seated in its center groove of the hinge,I cant envision it
  3. #13
    seat hinge
    Here is the passengers outside hinge (with the seat back latch) and the drivers outside hinge (no seat back latch). (1964-1965 vintage)
    Where are the washers located that secure a snug fit?
    As a side note and Off Topic are the pin on the seat angel lever.
    On the passenger side a hole was drilled and a cross pin inserted that holds the release lever so it can not move back and out of the conical gear slot.
    Drivers side does not have the pin (but is marked for drilling).
    The second Off-Topic is the conical gears on the drivers side - note an old autocross fix, locate the seat for proper driver fit, drill a hole and tap for the screw which holds the two conical gears in contact and is a non-movement pin which will not allowing the seat to change position in the heat of competition ....
    Bob
    Early S Reg #370
  4. #14
    Jan 2007
    North of the GG Bridge
    Quote Originally Posted by 300343 View Post
    anybody know the trick to get the spring back on, Ive chase the spring all over my garage anybodyknow of a tool maybe it take two people
    AIRC there are several tool designs out there I've seen through the years. I take no credit for the one attached as it was gleaned from the net some time ago, most likely from this site. It is basically a socket or pipe with a notch for the spring tail and a method for twisting it. Credit to whom ever originated this.
  1. WTB: Seat Hinge with locking 1973
    By FS1973 in forum For Sale: 911 Parts
    Last Post: 07-05-2013, 10:59 AM
  2. Seat Hinge Lever
    By Jacket in forum Technical Info
    Last Post: 09-04-2012, 04:50 PM
  3. WTB 72-73 seat hinge (black wrinkle paint)
    Last Post: 12-19-2009, 03:28 PM
  4. WT screws for hinge Sports seat
    By 91167coupe in forum For Sale: 911 Parts
    Last Post: 07-06-2009, 03:59 AM
  5. HELP, WTB Sport seat reclining hinge
    Last Post: 10-21-2005, 04:03 AM
Tags for this Thread
