Thread: Wiring Harness Opinions
    Going through a total restoration and trying to decide on attempting to protect and then refurbish the harness. Would like to conserve it but there is also the safety issue and expense of
    very old and brittle plastic. Any opinions or experience with original versus repro?
    Thanks!
    Aug 2011
    New York
    Contact Dennis (Timmy2)http://www.early911sregistry.org/for...ghlight=timmy2
    He does great work restoring and replacing wiring.
    E Sully
    1973.5 911T
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    If you want to stay with the original for the majority and just replace what's needed.
    http://www.mcmaster.com/ has the sleeves available.
    You can get the pressure sensitive tape at a number of places on the net.
    Kroon, or others can supply the brass terminal ends and the rubber protectors.
    Clean the wires up with a mild vinegar solution, so as not to destroy the trace paint on the wires.
    Vinegar and salt solution to clean the terminals, and a baking soda solution to neutralize the acid, and a bit of contact cleaner for protection.
    Lay it out and put some large jumper leads on your multi meter, and run continuity test on each wire, resistance can be from a short, or or a bad connection due to corriosion.
    It will take you time, but give you the opportunity to label each loom for when you put it back into the car, and save you $
    Tony
    Feb 2012
    Kolham, Groningen, The Netherlands.
    Hi, please note we do not only deliver new harnesses but also can refurbish your old harness in some cases. (depending on condition)
    This is only possible for the main harness and / or front to aft harness.
    Contact us for more info info@kroonwireharnesses.com
    Best regards,
    Gerard Kroon
    www.kroonwireharnesses.com
    Nov 2006
    S. F. Bay Area
    Quote Originally Posted by 50/50 View Post
    Thanks!
    Just elected to preserve the original, as it was reasonably good, but for changes for electronic ignition, audio, and ttg fogs. All back to original with tools and supplies from Kroon. Great stuff.
    Brian
    S Reg #1032
  1. Wiring Harness
    By ret9191 in forum For Sale: 911 Parts
    Last Post: 02-17-2012, 04:47 PM
  2. FS wiring harness '68 911 rhd
    By chasg in forum For Sale: 911 Parts
    Last Post: 12-26-2010, 07:53 PM
  3. WTB MFI wiring harness
    Last Post: 03-13-2009, 11:39 AM
  4. FS: 73 wiring harness
    Last Post: 05-19-2008, 06:42 AM
  5. Wiring Opinions
    By Tyson in forum Technical Info
    Last Post: 05-05-2004, 11:06 AM
