Results 1 to 10 of 10
Thread: 72-73 grill with 2.4 2.7 badge anyone know what the part number for mounting plate
    Feb 2007
    San Diego
    I just bought a shiny new 2.4 badge for my 73 grille and forgot about the mounting plate. The old one is no good with missing mounting posts. I can not find this as an individual part in any of my parts books. I can't find a part number, has anyone bought one of these mounting plates recently from Porsche?
    Oct 2010
    San Jose, CA
    Not available as a separate part. The plate was incorporated (welded?) between two of the grill members.
    Joe Hartman
    Early 911S Registry #157
    R Gruppe #174
    356 Registry
    Senior Member majordad's Avatar
    Dec 2012
    Cork , Ireland
    Were they not just glued on ?
    Jun 2012
    London, Ontario, Canada
    I'd think it was glued. Here's a NOS grill for 72-73. No weld points.
    Early 911S Registry # 2395
    Jul 2011
    Chicago Area
    Mounting plate was not welded on. Two of the grill cross bars had 4 holes drilled in them and the mounting plate had 4 corresponding pins that fit in these holes. Glue may also have been added but I think they just pushed into the holes and then emblem attached. I am looking for a mounting plate also.
    Mike Fitton # 2071
    2018 911S Carrera White
    agree..there are four small posts that went into corresponding 4 small holes in the grill...same question...is this mounting piece available
    Feb 2007
    San Diego
    Ravi, that is a beautiful NOS grille, I would be so jealous if I did not already have one of my own.....
    Now through pictures you can see that this is a conundrum. In these pictures you will see my NOS black anodized grille, it has no holes for the mounting plate.
    Then you will see the new 2.4 emblem which has a hollow back missing a mounting part.
    Then you can see my original grille with 4 mounting holes drilled into the grille, a missing procedure on a NOS grille!
    Then in the next post you will see the old mounting plate. This plate has 4 small studs that went into the holes on the grill. The 2.4 badge was then stuck to the mounting plate through double sided tape.
    I have to call out Porsche parts department on this one. WTF! There is no part or part number listed in the manual.
    Feb 2007
    San Diego
    more pictures
    I had the same issue a few months ago on a '74 grill. Ended up fabricating a mounting plate.
    Jun 2012
    Thanks Mark, that's a good lesson. The grill isn't mine. Just happened to be at the shop my car is being restored at. Didn't have a picture of my grill, but it is original and I bet it's got those 4 holes.
    I do believe Frank at Nineapart had some complete badge assemblies when I was there in the spring.
  1. WTB: Hood badge mounting pins
    By RS-GT in forum For Sale: 911 Parts
    Last Post: 04-30-2013, 05:19 PM
  2. Air box part number, what do I have?
    By tomt in forum Technical Info
    Last Post: 12-10-2011, 12:35 PM
  3. part number 901 107 696 40
    Last Post: 07-27-2010, 06:17 AM
  4. Help with part number 901.501.898.0
    By WM711 in forum General Info
    Last Post: 02-07-2007, 10:35 AM
  5. help ID this part number
    By typ901 in forum Technical Info
    Last Post: 01-18-2007, 12:40 PM
