Results 1 to 10 of 18
Thread: 7R wheels on the track?
    I have an original set of 7R wheels that have been refurbished by Harvey Weidman. I was thinking of using them on the track with my wets (Toyo 225/50/15 R888s) on the rear. Does anyone have experience using modern tires with 7Rs on a track? Are you using inner tubes?
    Thank you,
    Andrew
    1972 911 Narrow-Body Group 4 Project - On The Road.
    I always worry about using this type of rim with Tubeless tyres - although many people tell me my concerns are unfounded.
    I am sure, however, that running a tube inside a modern roughly finished tubeless tyre is unwise as the tube will tend to chafe and overheat.
    Chris - Thanks for the comment on tubes - I was thinking the same thing when running radials.
    Is there anyone running 7Rs on a track?
    Does autocross and 12,000 street miles count?
    Aug 2009
    SF Bay Area
    Quote Originally Posted by chris_seven View Post
    Chris
    You concerns are, indeed, unfounded.
    Running innertubes in tubeless tires is unwise.
    Jim
    No, because your experience does not validate the doom and gloom. You are the exception and not the rule.
    -Marco
    TLG Auto: Website
    I have seen 7Rs cracked radially from the lug hole to the triangle. This was at Summit Point a few years ago. Guy had one crack, then went out and got two more cracks.
    With the price of 7Rs, and the fact that they aren't quite the right offset anyway, why not use them for show, and go with a lighter, disposable, perfect offset wheel. When you are on the track you need the. . . er. . . freedom to operate over the turtles, off the edge, etc. "Grass is a racing surface" as they say.
    less wing, more brass bxd's Avatar
    Mar 2010
    S.F. Bay Area
    Yeah, I was kinda thinkin' the same thing... have Harvey make you a set of fake 7R weld-ups or use a pair of later 7s for the track, and leave the early (real) 7Rs for "parade" days. No sense in borking a matched pair of vintage race wheels that are quickly becoming the most expensive bits you can add to your car just to do a track day...there are alternatives that either look the same or very similar at 1/4 the price.
    Jordan
    rally-prepped '69 911T 3.0L
    S Registry #1933
    Vintage Parts & Restoration http://retro-sport.com
    Nov 2003
    Santa Monica CA
    Yes, have Harvey W. make you a set of 7R's. But you need 4 wheels to make two 7R wheels. for the inside wheels, you can get the cheaper flat 6's. Chris
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    Do us ALL a favor ... please please please please please stop cutting up Deep 6 wheels! They are getting expensive and much, much harder to find.
    Just start with something NEW ... www.group4wheels.com
    -Marco
    TLG Auto: Website
  1. FS: Fuchs set of wheels from midyear 911 15 x 7 and 8" track wheels or refinish
    By scwhite59 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 11-22-2014, 02:39 PM
  2. Wheels for track use
    By Chris Tallon in forum General Info
    Last Post: 01-25-2006, 05:20 PM
  3. 6X16 and 7X16 as track wheels
    By jkeithtalbot in forum General Info
    Last Post: 08-11-2004, 12:48 PM
  4. Deep Six for track wheels
    By wbs in forum Technical Info
    Last Post: 03-26-2003, 07:09 AM
