Thread: Clutch thickness
    Dec 2011
    Victorville CA
    Clutch thickness
    Is 5/16" or 7.9 MM thickness still a good clutch? If not what is the minimum thickness to re-use?
    You don't say what engine this clutch is for, but for example the dimension for a considered worn out 215mm disc is 7.8 mm lightly compressed. New is 9.2 lightly compressed.
    Dec 2011
    Victorville CA
    1600. I'm still saving for my 912-6 conversion
  1. Flange thickness of OEM heat exchanger ('67) ??
    Last Post: 03-05-2014, 04:34 PM
  2. Paint Thickness Measurements
    Last Post: 11-13-2009, 07:44 AM
  3. What is thickness of a new 2.4 flywheel?
    By caproader in forum Technical Info
    Last Post: 09-26-2009, 11:56 AM
  4. 911/912 unvented brake rotor thickness
    By cosley in forum Technical Info
    Last Post: 07-11-2009, 03:55 PM
  5. Thickness of 911 body steel?
    By Paul Schooley in forum General Info
    Last Post: 08-31-2006, 12:21 PM
