Thread: Price Check: Early MFI Stacks and Throttle Bodies
    Oct 2011
    Denver, CO
    Hi Guys, I have a set of early mag stacks and throttle bodies and would appreciate your input. They have been in storage for over 15 years and have been stored in a dry climate with a thin layer of oil/WD40 keeping them from corroding. The shafts are quite tight and the bores are very clean. I have had to have mag TB's sleeved due to corrosion and these will not need that sort of restoration. MFI stuff is going through the roof but I'm not looking to hit a home run, I just want a fair price.
    The TB's are #901.110.101
    The Stacks are #901.110.317
    Thank you for your time, Sean
    Senior Member BURN-BROS's Avatar
    Sep 2003
    Camarillo, Ca.
    Hi Sean,
    Those are for 1969 E sportomatic. I have not checked what they are going for at the moment.
    Aaron Burnham
    Burnham Performance
    1071 Avenida Acaso ste D.
    Camarillo, Ca. 93012
    805-240-6931
    _________________________
    Oct 2011
    Denver, CO
    Hi Aaron, good eye. Thank you. Do most people just thread a brass plug in the vacuum ports when running a standard trans?
    I appreciate your time, Sean
    Sep 2003
    Camarillo, Ca.
    It will work identical to the manual set up. The only negative is that it would not be visually accurate in the engine bay. If the potential buyer does not mind, then you both win.
    Aaron Burnham
    Burnham Performance
    805-240-6931
  1. FS: MFI '70/'71 E mag stacks and throttle bodies
    By haycait911 in forum For Sale: 911 Parts
    Last Post: 01-19-2013, 12:03 AM
  2. FS - '69 MFI throttle bodies and mag stacks
    Last Post: 12-05-2009, 10:04 AM
  3. 2.2 S throttle bodies & stacks
    By Eminence Gris in forum For Sale: 911 Parts
    Last Post: 01-17-2009, 06:10 AM
  4. WTB 2.4E MFI Stacks and Throttle Bodies
    By orange911 in forum For Sale: 911 Parts
    Last Post: 01-20-2008, 03:31 PM
