Results 1 to 10 of 10
Thread: fitting of trunk carpet around washer bottle in 73 with A/C
    Nov 2011
    Reston, VA
    I just finished getting the windshield washer system installed and working on my 73 911T. It's got A/C, so the windshield washer bottle is back near the cowl. Now I need to know how the trunk mat is cut and fit. Photos would help, and if some kind soul is willing to take a few measurements that would be great. From what I recall seeing, there is a slit in the floor mat just to the passenger side of the bottle, and a hole for the neck. Ideally, I need measurements for the start location and length of the slit and location and size of the neck hole. Also, does the side piece just get stuffed under the bottle, or does it sit on top?
    [Note: Sorry about the upside down image, tried to fix but not successful]
    --Richard
    Early 911S Registry #2337
    Sep 2006
    San Francisco
    You must be down under!
    If no gets to it today I can measure mine tonight.
    Jeff
    Jeff Jensen
    Nov 2011
    Reston, VA
    Thanks Jeff. One way or the other I need to carve up the mat. I'd much rather have some measurements than not, no matter how careful I am.
    Chuck, thanks for flipping the photo. I tried uploading an upside down version but no go. Is this something we can learn to do for ourselves?
    --Richard
    Man, I don't know Richard...
    I just save your pic to another picture file I have on my desktop and flipped it in a standard photo edit program then re-posted the flipped pic back to your thread...........
    Sep 2006
    San Francisco
    Here is a photo, as well as a sketch with dimensions. I believe my carpet is original. It was in the car when I purchased it 30 years ago.
    The slit is 13" long, and offset 1" to the right (looking from front to back) of the cutout for the driver's side support bar. The slit starts 2" below the cutout. Another 3.5" down the cutout for the water bottle neck begins. It is about 2.5" deep and the opening at the slit is 1". See the attached sketch and I hope this makes sense. Let me know if any questions.
    EDIT: Upon closer inspection the top edge of the carpet only has one cutout. That's the one you reference from. I thought there was a corresponding cutout on the passenger side but there is not.
    Jeff Jensen
    Senior Member gregbus's Avatar
    Feb 2011
    Lake Tapps, WA
    Morning Richard. Great info on this thead! I have a 72 with the same factory a/c setup. Thanks for providing the measurements and pic Jeff
    I've been looking for a washer bottle strap for this, but no luck yet. Is that a repop or is it an original one?
    Greg
    Greg
    “Whether you think you can, or you think you can't...you're right.” - Henry Ford
    Nov 2011
    Reston, VA
    Thanks Jeff -- very helpful and now (finally!) done.
    --Richard
    Nov 2011
    Reston, VA
    Greg, the strap is a repro. I found it on Stoddard as part SIC-611-025-21, labeled as "Battery Strap for 356C and early 911 / 912, larger metal loop on one end, 3.5mm thick." Hooking it onto the cardboard shield, while correct, didn't seem like a good idea, so I made an L-shaped bracket (see photo).
    --Richard
    Nov 2011
    Reston, VA
    I did some experimentation. Will PM some comments.
    --Richard
    Feb 2011
    Lake Tapps, WA
    Hi Richard...thanks for the info (and the part number)! I'm replacing my blower motor cover for that same reason. They can only last so long with the strap attached I like your idea of the bracket as well. The one you made looks nice!
    Greg
  1. Replies: 0
    Last Post: 07-01-2011, 12:54 PM
  2. WTB: '67 Washer Bottle...
    By jaudette3 in forum For Sale: 911 Parts
    Last Post: 09-30-2009, 04:29 PM
  3. FS: Washer Bottle SWB 911/912 65 -67
    By 67softwindow in forum For Sale: 911 Parts
    Last Post: 09-09-2009, 11:41 PM
  4. WTB Washer Bottle 67 or 68
    By hdavis in forum For Sale: 911 Parts
    Last Post: 05-17-2009, 05:10 PM
  5. swb Charcoal German Square Weave Carpet & trunk carpet kit
    By hoffman912 in forum For Sale: 911 Parts
    Last Post: 06-27-2007, 02:10 PM
