Results 1 to 7 of 7
Thread: WTB: 2 Rubber Drain Hoses under ventilation box : ref 90157132632 AND 91157122400
    Hi,
    looking for 2 rubber drain hoses under the fresh air box called also connection part
    ONE SMALL and ONE LONG
    small rubber to collect water at the bottom of the air box, number 19 on the drawing :
    thank's !!!
    fred ©
    Feb 2007
    San Diego
    #19 in the drawing was NLA from Porsche last time I checked. I have asked a couple of the rubber manufacturers to reproduce that part but they told me "no one ever asks for that". No luck making one so far. It is kind of important as water needs to drain from the fresh air vent and go out of the car, not in the trunk.
    Yes, that's why i need one for a 912 friend (short model) and one for my 72
    thanks
    fred ©
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    I ended up getting a piece of clear tube with the same OD.
    RHD cars are a little different in that it only needs the small tube, as it has a welded in pipe that exits the body.
    Tony
    Feb 2011
    Surrey, UK
    You can make one (for the short one - 19) out of standard heater tube from a water-cooled car (I think I used ¾") - in order to get it to go over the outlet on the box you need to find something (or make something) that is conical at the end so as to force one end to enlarge. I shaped a piece of hardwood dowel. Leave it in hot water for a couple of hours, force it in a bit more until the enlarged section is long enough, dunk again in hot water, and leave it until the deformation is permanent.
    Cut to length and use the clip to attach to the box.
    Looks identical to original and works fine.
    I have never found an original in re-useable condition - they were all split at the end of the enlarged section.
    Mick
    Any picture ?
    Fred
    May 2006
    Riverside CA 92505
    drain hose
    There is a drain hose sold at common hardware stores like Home Depot or Lowes. It is in the garden section and sold as 1" irrigation hose. I have used it on 914 engine bay drain hoses. It fits fine and has spiral ridges instead of circular ridges. It sell for $20 for a 20 foot roll. Not original but it looks close and works.
    Bruce
  1. Heating and Ventilation controls - HELP !
    By oldtimer in forum General Info
    Last Post: 09-30-2016, 02:58 PM
  2. Question: original looking rubber brake hoses for a '67
    Last Post: 07-24-2013, 04:39 PM
  3. Crankcase Ventilation
    By Jens in forum General Info
    Last Post: 09-11-2012, 05:59 AM
  4. FG Front Bumper Ventilation
    By CamBiscuit in forum Technical Info
    Last Post: 07-15-2008, 07:51 AM
  5. WTB: ventilation fiberboard cover
    By Kaleid in forum For Sale: 911 Parts
    Last Post: 04-12-2008, 05:51 AM
