Results 1 to 8 of 8
Thread: CJ Joint grease
    Banned
    Nov 2004
    Scottsdale, AZ
    CJ Joint grease
    Another thread reminded me of this:
    THE ABSOLUTE BEST CVJ GREASE ON THE PLANET?
    Dupont Krytox.
    CV joints used to be a constant sore spot on our race cars. Went to this and no more failures. AT ALL.
    It's like tar and seems to actually coat the parts. And your hands.
    Here's the rub: It's $350 a tube... and worth every penny.
    I use a white/clear krytox at work for O-rings and stuff. Comes in a tub that's about a thousand dollars.
    Frank, we used Mobil 1 Synthetic Grease at Swift on Formula Atlantic CV joints, Indycar tripods and FA/Indycar wheel bearings in 1990's. Worked very well in extreme applications, no problems that I recall. Not very expensive.
    Jon B.
    Vista, CA
    Banned
    Nov 2004
    Scottsdale, AZ
    Quote Originally Posted by Jon B View Post
    Jon B.
    Vista, CA
    Our challenge is that we use the little Formula Ford joints in 2000 lb cars and 350hp.
    May 2011
    Chelsea, Québec
    Member #1616
    Dec 2008
    Woodland Hills, CA
    The only thing it seems to coat and stick to is my hands. And I just make a mess.
    Indycar wheel bearings at Michigan, Fontana for 500 mile races, doing 240 mph laps, is an extreme test for bearing lubricants. I'm sure Dupont Krytox has superior aspects, but Mobil 1 is a very effective CV grease for much less money.
    Jon B.
    Vista, CA
    klueber
    not as expensive and not as dangerous as krytox (see msds)
  1. CV joint grease
    By Merv in forum Australia
    Last Post: 12-21-2013, 11:48 AM
  2. Wheel Bearing Grease
    By Richardnew in forum Technical Info
    Last Post: 02-25-2013, 09:23 AM
  3. Replies: 0
    Last Post: 10-09-2011, 06:29 AM
  4. Which way for front grease seals?
    By Zeke in forum Technical Info
    Last Post: 09-28-2003, 07:25 AM
