Results 1 to 7 of 7
Thread: Need advice on ordering proper replacement shocks
    Senior Member BrentF's Avatar
    Sep 2012
    Toronto
    I have a '70 911T that according to the COA came from the factory with Koni shocks. Here is a present day photo:
    I wish to replace these shocks and want to make sure I order the correct shock replacement, as there are several types. Is this the correct replacement for my current set-up?
    Also, are there other shock related components I should replace while replacing the front shocks? TIA
    Brent,
    These are probably the right ones.....
    However, I'd still give Jason at Paragon Products a call... I've found that Jason is the one to ask about Konis for our old cars...
    http://www.paragon-products.com/default.asp
    800-200-9366
    Hope this helps...
    Holiday Cheers,
    Chuck
    Feb 2003
    Los Angeles
    Jason was very helpful with my Koni purchase. I would recommend him too.
    Check you ball joints at the same time.
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
    Oct 2010
    Florida
    Here's an article I wrote about shocks last year. It may be a little more than what you're asking for but it is about shocks. btw - you might consider having your current shocks rebuilt. Especially if you've changed anything from stock. If you change the torsion bars or sway bars you might need a custom rebuild.
    Also, remember that shocks are the final step in your handling package. You only do shocks when you have the springs and sway bars correct.
    Richard Newton
    Sep 2012
    Toronto
    Thanks for all the comments and thanks Richard for the link to your article. Another forum member sent me a PM also suggesting the rebuild route and mentioned Koni offers a rebuild service This is an option that I was not aware of and so did some more searching on the web. Koni USA's rebuild service that can be accessed here:
    http://www.koniracing.com/services.cfm
    Feb 2003
    Corpus Christi, Texas
    Brent, the KONI 86-1638 insert would be correct for your original Koni strut. I think if you look around a bit you can probably save a bit of money ;-).
    Jason (drinking coffee waiting for the boy to wake up and see what Santa brought!)
    Jason Burkett
    Paragon Products
    Early 911S Registry #428
    R Gruppe #375
    1973 911S
    1972 911T
    1974 914 Limited Ed. Blk/Yellow
    1989 944 Turbo
    1993 968 Turbo RS
    1967 Shelby GT500
    1968 Shelby GT500 Conv.
    2010 VW GTI, Daily Driver
    Sep 2012
    Toronto
    Thanks Jason for the compatibility confirmation....... and the advice. Merry Christmas.
  1. Replies: 8
    Last Post: 09-16-2015, 08:50 PM
  2. Replacement pressure plate advice
    By ajwans in forum Technical Info
    Last Post: 07-25-2013, 10:09 PM
  3. What is correct replacement shocks for 73 911 T ?
    By LV911 in forum Technical Info
    Last Post: 05-19-2013, 01:06 PM
  4. 901 Transmission Mount Beam - Repair/Replacement Advice Wanted
    By StephenAcworth in forum Technical Info
    Last Post: 02-15-2013, 03:40 PM
  5. need advice - clutch cable replacement
    By tadink in forum Technical Info
    Last Post: 01-19-2009, 09:12 AM
