Thread: Speedometer and Tachometer needle sticking.
    About a year ago, on occasion after sitting for a week, my speedometer needle would stick until I would reach about 25 MPH. If I taped the glass it would immediately register. Now my tach needle sticks until I tap the glass and then will respond accurately. I have checked speedometer cable and all electrical connections on tack, MSD and points. If I pull out tach at idle and move it around a bit while checking connections nothing happens until I tap on the glass.
    Any ideas.
    Jan 2011
    DFW TX
    It is the gauge itself. Dry/ sticky/old lubrication inside on the bearings the needle shaft rotates on.
    Dec 2008
    Woodland Hills, CA
    My oil pressure gauge does the same thing when first started. A tap on the glass gets her working.
  1. Replies: 6
    Last Post: 07-22-2014, 04:49 PM
  2. FS: 914/6 Timing sticking
    By WES914 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 01-21-2014, 12:49 AM
  3. Headlight high beam switch sticking need assistance
    By muncokiho in forum Technical Info
    Last Post: 01-06-2014, 06:15 PM
  4. Bouncing speedo needle help
    By cjtbt in forum Technical Info
    Last Post: 07-19-2010, 04:50 AM
