Thread: Help me fish out my 73.5T's hood latch cable
    Member bford's Avatar
    Nov 2012
    San Jose, CA
    Yesterday I rekeyed the lock to my glove box on my 73.5 T. That was so easy that I decided to rekey the lock for my trunk as well (it's a Targa). I backed out the screw at the hood latch and the little stop-screw behind the "T" pull handle, and then pulled the T and it came out enough to get at the lock and remove the tumbler cylinder. The rekeying went smoothly as did reinstalling it into the handle. But now, we get to the problem. In pulling the T handle out, the latch cable got pulled back inside the metal tube shielding. Pushing in on the T handle is not forcing it forward -- see this video. and pics below. The cable had a little bend near the latch, it must be catching inside the tunnel. Any good suggestions for how to fish the cable out? There's about zero room to maneuver in there.
    Thanks in advance.
Size:  86.6 KBName:  IMG_2242.jpg
    Brad
    '73.5 911T Targa (Kaptain Karmel)
    Early S Registry #2585
    The "hook" is created as the cable is bent over after passing through the hole with the set screw. Get the length correct before you bend it. I'd pull it and but a new one unless you are able to fish it out with a piece of safety wire or similar.
    Good luck.
    Early S Registry #235
    rgruppe #111
    Can you not just pull the cable out from the 'T' handle end?
    Nov 2012
    San Jose, CA
    Thanks Ed, that turned out to be the winning solution. I couldn't push it back in, but was able to pull the cable all the way out, straighten the last half inch of cable with needle nose pliers, then feed it back in all the way through to the latch.
    Brad
  1. Front Hood Latch Cable question
    By 21window in forum Technical Info
    Last Post: 10-08-2013, 03:28 PM
  2. Replies: 10
    Last Post: 03-05-2012, 12:44 PM
  3. Where to get a new cable housing for the hood release cable?
    By Sandwich Boy in forum Technical Info
    Last Post: 07-15-2009, 05:31 PM
  4. WTB Front hood latch top and bottom with cable if possible
    By Gringo in forum For Sale: 911 Parts
    Last Post: 10-13-2008, 11:08 AM
  5. Front hood latch backup cable?
    By pwd72s in forum Technical Info
    Last Post: 12-16-2002, 11:54 AM
