Results 1 to 2 of 2
Thread: Routing of oil lines to front cooler
    May 2010
    Sanford, NC
    Good Morning!
    I am working on the rocker panels / floor and I got to thinking about how to route the oil cooler lines while everything was open. Car is 1970 911. Elephant racing has the hard lines that seem to go on the outside of the car. Given my propensity for off-course excursions, having the oil line as the first point of contact does not seem good. (stones and small objects, not a side impact with something large)
    I am going to have a header without heater boxes, so there will not be a heating duct. It is possible / recommended to use braided oil lines and run them through the ducting area in the rocker panels and then use the heater piping to routing the braided lines into the trunk area and then to a fender mounted cooler?
    Thanks in advance.
    Rick
    Rick,
    I did this set-up in the 70's and I go through the complete project. Send me your phone number directly to my email at johndilger@aol.com and I will call you to go over the details. There are special fittings and wrenches that you need to use.
    John Dilger
    John Dilger
  1. Replies: 1
    Last Post: 10-08-2012, 10:12 AM
  2. front cooler lines ?
    By joetiii in forum Technical Info
    Last Post: 12-26-2007, 08:24 AM
  3. NOS 1969 Front Oil Cooler Lines
    By boxster03 in forum For Sale: 911 Parts
    Last Post: 06-06-2007, 05:42 AM
  4. NOS Factory Front Oil Cooler Lines
    By RTincher in forum Technical Info
    Last Post: 03-31-2007, 10:14 PM
  5. WTB: 73 Hard Front Cooler Lines
    By rick2 in forum For Sale: 911 Parts
    Last Post: 03-01-2006, 05:48 PM
