Results 1 to 9 of 9
Thread: satin black paint for engine bay
    Junior Member
    Apr 2012
    Ft. Worth, Texas
    I am restoring a 1970 E Targa and have read in this forum that the correct color for the engine bay and wheel wells is satin black and not the body color. Specifically what satin black paint should be used. Thanks.
    There will be as many different answers as there are replies,,,,,but my answer is cheap and simple,,,,,rust-oleum satin black brushed on, as was the original method.
    Jul 2006
    Corvallis, OR
    Wurth Satin Trim Black works great! More expensive but a can goes a long way. And what Ed said.
    72S, 72T now ST
    +1 on Rustoleum Satin Black. Apply it with a disposable foam brush or small roller. Doesn't leave brush marks or brush hairs in the paint. Looks great, fairly original and is easy to keep clean.
    Cheers,
    Ron
    1961 356 Roadster Outlaw
    1969 911E ROW Coupe ‘Orangina’
    1968 911 SWT Burgundy Red project
    Junior Member
    Apr 2012
    Ft. Worth, Texas
    Rustoleum satin black it will be! Thanks for the help.
    Oct 2012
    Minneapolis
    has anyone had issues with the rustoleum not being able to deal with chemicals such as brake cleaner, or whatever?
    -Kris Clewell
    Professional photojournalist
    red decklid club member #1
    Nov 2006
    S. F. Bay Area
    Quote Originally Posted by rdelmendo View Post
    Actually, a few brush marks would be closer to original appearance.
    Brian
    S Reg #1032
    Senior Member DavidRees's Avatar
    Dec 2011
    Sarasota,FL
    Are these two products also correct for the undercarrage (belly pan)
    Certainly are, and I'm sure all done at the same time, only way to do stuff on a production line, and brushed on so no need to mask.
  1. Luggage compartment SWB - satin black question
    By IAA1963 in forum Technical Info
    Last Post: 08-15-2011, 07:02 AM
  2. Dash face color (Satin Black?)
    Last Post: 08-07-2011, 12:51 PM
  3. Gas filler cavity - satin black or bodycolor - on SWB
    Last Post: 08-06-2011, 11:48 PM
  4. Correct satin black on inside of doors?
    Last Post: 09-30-2008, 08:56 AM
  5. Masury satin black paint
    By Tom F. in forum Technical Info
    Last Post: 06-29-2005, 01:18 PM
