Thread: Camber plate stuck to insert...Help Pls
    Senior Member timgt3's Avatar
    Oct 2010
    Gold Coast, Australia
    I am having trouble removing the camber plate from the strut insert. The other side I heated up the bush and melted it off leaving the metal sleeve. I ended up grinding it off.
    I don't want the insert but don't want to go throughout the same process as above.
    i have left it overnight with WD40, like I did with the other side. It made no difference on the last one. Using a BF Hammer didn't budge the insert either.
    Tim Pritchard
    1970 911S (resto underway) http://www.early911sregistry.org/for...ge-1970S-resto
    1976 Carrera 3.0 Group Sc Race Car
    1969 911T Group Sb Race Car (Sold to a good home)
    Maybe a hydraulic press,,,,,,set the camber plate on the press rails and push against the the shock insert.
    If you aren't going to use the insert, I would support the camber plate like Ed says, and hit it with a hammer. The impact might help break up the rust holding it together.
    Oct 2010
    Thanks guys. I bought a press. Should have done it ages ago. Unfortunately i pressed the rubber bush out of the camber plate, but the bush and sleeve are still well bonded to the insert. Next?
    Tim Pritchard
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Tim is there not enough room to just cut the threaded portion on the insert now?
    I am assuming its the strut, and not the insert you're trying to save?
    Tony
    Oct 2010
    So pressed the insert and gripped the rubber, the rubber broke away, so back to square one. I ground off the sleeve. Either way they are off and apart.
    Funny thing is, I was on to the 1970S struts next. These are looking pretty nasty. Rattled off the nut, and the camber plates slipped right off on both. I guess you can have a win sometimes as well!
    Tim Pritchard
  1. Camber Plate Bush
    Last Post: 11-30-2013, 10:17 PM
  2. Early Camber Plate Rubber Bushes
    Last Post: 10-09-2009, 03:14 AM
  3. Spring plate stuck on torsion bar...help
    By Sacto S in forum Technical Info
    Last Post: 05-15-2007, 11:36 AM
  4. camber plate front strut
    By thback in forum Technical Info
    Last Post: 09-18-2002, 02:23 PM
  5. More camber please!
    By B rad racer2 in forum Technical Info
    Last Post: 02-13-2002, 10:46 AM
