Please send me a PM and asking price, if you got a nice set of Hella driving light TN-4 reflectors, lenses, and mounting brackets laying around. I'll take a good used driver condition as well. Thanks in advance. Andy
Andy (VA).
118 (mm lenses/bezels) do not match TN4 reflectors which are a 115 (mm lenses/bezels). The 118 "Euro" driving and fog lights use an H1 or H3 bulb. THe TN4 reflectors are tungsten (much lower wattage bulbs). The items common to 118s and 115s are: chrome housings (basically the same), little squiggely bezel holding bracket/screw, and swivels. So, what are you after? Thanks.
-Allen-
Hi Allen.
Thanks for the clarification. Upon closer inspection, it looks like I have a set of bastardized Hella lights (TN-4 body with 118mm lens and chrome bezel). So I'll go with TN-1/2 reflectors for these 118mm lens and bezel combination. Please let me know if you have a good driver reflector set? Thanks again. Andy
Andy (VA).
Hi, I have 2 pairs of NOS TN1-TN2 Lights see
http://www.early911sregistry.org/for...N1-TN2-TTG-Fog
Cheers
ULI
Rats!! Just when I thought I've got it :-). Allen, please bare with me as I'm as thick and as slow as they come. I'm I to understand that:
1) Euro cars came with 118 mm TN1-TN2 lenses, TN1-TN2 reflectors, using H3 bulbs (Italian cars used H-1 bulbs). Some suppliers will use tractor lights body which uses 118 mm TN1-TN2 reflectors, and then add 118 mm TN1-TN2 lenses to make the set more correct.
2) U.S cars came with 115 mm TN4 lenses, TN-4 reflectors, using Tungsten bulbs. It is the same set up as 914's fog light set ups except for the black housings. The reason I have 115mm TN1-TN2 lenses is the previous owner put it on to make it looks like a Euro car?
3) To make my set work, I should be looking for the U.S. 914s fog lenses and reflectors, both of which originally came as 115mm TN4s an uses tungsten bulbs?
Yes, I do have a pair of these 115mms lights.
Thanks again for helping me get smart. Andy
Andy (VA).
TN1-TN2 lenses are 115 and interchange with TN4 lenses which are original to USA Porsche. I have good TN type reflectors, PM me if interested.
