Results 1 to 8 of 8
Thread: Should the air intake hose for 1972 911T connect to anything?
    Senior Member SpawnyWhippet's Avatar
    Mar 2013
    San Francisco Bay Area
    My 911T was missing all the air intake parts when I bought it. I have tracked most / all of them down, but there is a silver hose that goes from the air intake box through the engine bay floor. Should this hose connect to anything, or just suck in cold air from under the car? It seems to be too long to just poke through the floor?
    Name:  Air intake 1.jpg
    Name:  Air intake 2.jpg
    Sorry about the barrage of questions I am posting, but I am new to the area and have no other cars or Porsche guys that I can refer to. However, my learning curve is steep and I hope to be able to contribute back to the forum soon!
    Member # 2899
    1972 911T
    2004 996 C4S
    2001 996 Carrera
    2008 Cayenne S (sold)
    2004 Cayenne Turbo (sold)
    2009 997 cabriolet (sold)
    2002 996 Turbo (sold)
    1998 Boxster S (sold)
    1997 993 cab (sold)
    1989 911 3.2 Carrera (sold)
    Jun 2011
    Bellingham, WA
    It connects with the heat exchanger. Next to the similar hose for heat
    Tom
    Those may be SSI heat exchangers without the hot air box for that hose to connect to.
    Feb 2010
    San Francisco, CA
    As was mentioned above this hose connects to the pre-heat box on the original style heat exchangers. Your SSI exchanger doesn't appear to have this additional box (mine doesn't either). I've heard that the new run of SSIs can be ordered with the pre-heat box, but can't confirm this.
    As far as your hose is concerned, I'd disconnect it and cover up the hole in the engine tin. As it sits, it's not performing any function and since the hose is so low to the ground, your likely sucking up dirt etc kicked up by your rear tires.
    Cheers
    Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    Mar 2013
    Great, thanks for all the useful info, my SSI exchanger has no connection point, so I'll follow Kents advice and disconnect the silver hose
    Member # 2899
    1972 911T
    2004 996 C4S
    2001 996 Carrera
    1997 993 cab (sold)
    Feb 2010
    San Francisco, CA
    Depending on how much of a stickler for originality you are you could also remove the pre-heat flapper box and rubber hose that connects it to the air box. This was SOP for most of these back in the day. Just save it in a box somewhere.
    Removing the clutter cleans up the look of the engine bay and will only serve to help the airflow. It's absolutely not needed in Nor-Cal.
    E911SR & RGRUPPE
    '73 S Coupe #306
    Mar 2013
    Wow, nice clean bay! I could have saved myself $300 not buying the pre-heat flapper box and rubber hose! At least I now have those for when I pull my motor and detail the engine bay properly
    Member # 2899
    1972 911T
    2004 996 C4S
    2001 996 Carrera
    1997 993 cab (sold)
    Feb 2010
    San Francisco, CA
    Nah, that pic was taken back when my engine bay was sloppy
    It never hurts to accumulate original parts, even if they don't end up on the car. I bought a nice set of sugar scoop headlights that I really have no intention of ever putting on. Still, nice to have them for an unforeseen sealed beam headlight fad! Haha.
    Cheers
    E911SR & RGRUPPE
    '73 S Coupe #306
  1. WTB: oil hose fitting for 1972
    By naba901R in forum For Sale: 911 Parts
    Last Post: 01-06-2014, 12:50 PM
  2. R Gruppe re connect help
    By geneulm in forum General Info
    Last Post: 01-16-2012, 05:56 PM
  3. need the air intake hose, 73 E
    By cmcfaul in forum Technical Info
    Last Post: 02-24-2011, 12:57 AM
  4. WTB 911T intake manifolds for Webers.
    By demo in forum For Sale: 911 Parts
    Last Post: 03-14-2008, 08:05 AM
  5. Original 1972 911S Oil Hose Needed
    By lotus15racer in forum Technical Info
    Last Post: 01-15-2008, 07:50 PM
