Results 1 to 2 of 2
Thread: Can MFI from a 73T be fitted to a 73E?
    Can MFI from a 73T be fitted to a 73E without substantial modification? Thanks.
    Senior Member boba's Avatar
    Jul 2006
    DFW
    What do you consider substantial? The injection pump is corolated to the cams and ignition. So for best performance the pump would need to be re-calibrated for E spec. This would include a space cam change for the pump.
    Without this it could probably be made to run, but not at optimum performance.
    65 356SC Dolphin Gray
    66 912 Green
    69 911E Tangerine
    72 911T GP White
    72 911T Aubergine
    72 911T Lilac
    72 911S Black (voodoo)
    90 964C4 Black Targa
    94 964C2 Black Coupe
    08 GT3 Speed Yellow
  1. Factory fitted tires on december '65 car
    By 718RSK in forum General Info
    Last Post: 07-10-2013, 07:03 AM
  2. What Wheels Factory Fitted to my Car?
    By leedurrant73 in forum Technical Info
    Last Post: 08-02-2012, 03:23 PM
  3. Can a speakerless grill dash be retro fitted?
    By caproader in forum Technical Info
    Last Post: 07-24-2009, 10:40 PM
  4. Factory fitted RS Oil Cooler on 73S
    By acf321 in forum Technical Info
    Last Post: 06-04-2008, 08:12 AM
